Hi francois,
I confirm you the interest to implement the ISO19119 in GN to use in Geosource. I'll split in 3 tasks :
1 / Add a new schema in GN with 19119 implementation and definition of specific template to access it.
2 / Allow the link between an service MD and Data MD. If you create a Service MD, a specific field allows to link ("OperatesOn") with datasets. With data MD, no link available with 19115 standarsd. In GN, two solutions to manage the link :
- add a link table of MD. This table allows to manage the link 19115/19119, but also 19115/19115, 19115 / 19119 and so one.
- use only the OperatesOn attribute in the 19119 standards.
I prefer the first solution but need a "important" change of GN.
3 / Create a useful interface to add the link between the two metadata. I explain. Currently, When you create a MD 19115 (or 19139), you could quickly add a WMS address (in distribution/onlineresource). With 19119, you have to create a specific service 19119 file to identify the WMS address (it's a service !). Perhaps the use of subtemplates but I don't really success in using with beta version...
A first proposition for the discussion...
Pierre,
De : geonetwork-devel-bounces@lists.sourceforge.net [mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de François Prunayre
Envoyé : vendredi 6 avril 2007 08:12
À : geonetwork-devel@lists.sourceforge.net
Objet : [GeoNetwork-devel] ISO19119
Hi, anyone working on implementing ISO19119 (Geographic information : services) in Geonetwork ? I will be interested on discussing that topic if some of you are working on that.
Thanks for any feedback.
Francois
Le contenu de ce mél et de ses pièces jointes est destiné à l'usage exclusif du
(des) destinataire(s) expressément désigné(s) comme tel(s). En cas de réception de ce
mél par erreur, le signaler à son expéditeur et ne pas en divulguer le contenu.
L'absence de virus a été vérifié à l'émission du message. Il convient néanmoins de
vérifier l'absence de contamination à sa réception.
The contents of this email and any attachments are confidential. They are intended for
the named recipient(s) only. If you have received this email in error please notify the
system manager or the sender immediately and do not disclose the contents to
anyone or make copies. eSafe scanned this email for viruses, vandals and malicious
content.
