[GeoNetwork-users] [GeoNetwork-devel] stumped by MEF import error "Root element not set"
Wolfgang,
That explains the same problem I was having, had me stumped too!
Using 2.4.1 I was re-inserting some metadata produced by the xml show feature
and got the same error message. See ticket #150 on the Geonetwork trac
site http://trac.osgeo.org/geonetwork/wiki, SimonP is on the case.
Andrew
  ----- Original Message -----
  To: GeoNetwork-devel@lists.sourceforge.net
  Sent: Thursday, November 05, 2009 10:23 AM
  Subject: Re: [GeoNetwork-devel] stumped by MEF import error "Root element not set"
  My bad. I referenced a CSW name space that is not part of ISO 19115 (leftover from my CSW insert transaction xsd).
  WG
_______________________________
Wolfgang Grunberg
Arizona Geological Survey
wgrunberg@anonymised.com
520-770-3500
  Wolfgang Grunberg wrote:
    I am stumped by a "Root element not set" error when importing my MEF files through the metadata insert form, the batch metadata upload form, and when submitting the MEF file to /srv/en/xml.metadata.insert (GeoNetwork 2.4.1). The metadat.xml is ISO 19139 schema valid and I can't see anything wrong with my info.xml.
    What am I missing?
    Following is the error for my multipart/form-data POST to /srv/en/xml.metadata.insert. I ahve attached an example MEF
    2009-11-04 14:46:09,648 INFO [jeeves.request] - ==========================================================
    2009-11-04 14:46:09,648 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/xml.user.login
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Method : POST
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Content type : application/x-www-form-urlencoded
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Accept : text/plain
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Session id is F08E0763DA2E8A0391219CCB56642CA0
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Session created for client : 127.0.0.1
    2009-11-04 14:46:09,648 INFO [jeeves.service] - Dispatching : xml.user.login
    2009-11-04 14:46:09,648 DEBUG [jeeves.service] - -> parameters are :
    <request>
     <password>admin</password>
     <username>admin</username>
    </request>
    2009-11-04 14:46:09,648 INFO [jeeves.webapp.xml.user.login] - User 'admin' logged in as 'Administrator'
    2009-11-04 14:46:09,648 INFO [jeeves.service] - -> dispatching to output for : xml.user.login
    2009-11-04 14:46:09,648 INFO [jeeves.service] - -> writing xml for : xml.user.login
    2009-11-04 14:46:09,648 DEBUG [jeeves.service] - Service xml is :
    <ok />
    2009-11-04 14:46:09,648 INFO [jeeves.service] - -> output ended for : xml.user.login
    2009-11-04 14:46:09,648 INFO [jeeves.service] - -> dispatch ended for : xml.user.login
    2009-11-04 14:46:09,648 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/mef.import
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Content type : multipart/form-data; boundary=192.168.56.1.1.412.1257371169.648.1
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Accept : null
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - Uploading file C:\azgs_borehole_mef\082FFAC8-AFA7-44A5-8870-86AEA5C12DC1.mef type: application/octet-stream size: 13877
    2009-11-04 14:46:09,648 DEBUG [jeeves.request] - File is called 082FFAC8-AFA7-44A5-8870-86AEA5C12DC1.mef after simplification
    2009-11-04 14:46:09,664 DEBUG [jeeves.request] - Adding to parameters: <mefFile type="file" size="13877" content-type="application/octet-stream">082FFAC8-AFA7-44A5-8870-86AEA5C12DC1.mef</mefFile>
    2009-11-04 14:46:09,664 INFO [jeeves.service] - Dispatching : mef.import
    2009-11-04 14:46:09,664 DEBUG [jeeves.service] - -> parameters are :
    <params>
    </params>
    2009-11-04 14:46:09,710 DEBUG [jeeves.webapp.mef.import] - Adding metadata with uuid=082FFAC8-AFA7-44A5-8870-86AEA5C12DC1
    2009-11-04 14:46:09,710 ERROR [jeeves.service] - Exception when executing service
    2009-11-04 14:46:09,710 ERROR [jeeves.service] - (C) Exc : java.lang.IllegalStateException: Root element not set
    2009-11-04 14:46:09,710 DEBUG [jeeves.service] - Raised exception while executing service
    <error id="error">
     <message>Root element not set</message>
     <class>IllegalStateException</class>
     <stack>
       <at class="org.jdom.Document" file="Document.java" line="218" method="getRootElement" />
       <at class="jeeves.utils.Xml" file="Xml.java" line="185" method="transform" />
       <at class="org.fao.geonet.kernel.DataManager" file="DataManager.java" line="2036" method="updateFixedInfo" />
       <at class="org.fao.geonet.kernel.DataManager" file="DataManager.java" line="1998" method="updateFixedInfoExisting" />
       <at class="org.fao.geonet.kernel.DataManager" file="DataManager.java" line="920" method="insertMetadataExt" />
       <at class="org.fao.geonet.kernel.mef.Importer$1" file="Importer.java" line="200" method="handleInfo" />
       <at class="org.fao.geonet.kernel.mef.MEFFileVisitor" file="MEFFileVisitor.java" line="93" method="handleXml" />
       <at class="org.fao.geonet.kernel.mef.MEFFileVisitor" file="MEFFileVisitor.java" line="50" method="visit" />
       <at class="org.fao.geonet.kernel.mef.MEFLib" file="MEFLib.java" line="62" method="visit" />
       <at class="org.fao.geonet.kernel.mef.Importer" file="Importer.java" line="86" method="doImport" />
     </stack>
     <request>
       <language>en</language>
       <service>mef.import</service>
     </request>
    </error>
    2009-11-04 14:46:09,710 INFO [jeeves.service] - -> dispatching to error for : mef.import
    2009-11-04 14:46:09,726 INFO [jeeves.service] - -> transforming with stylesheet : C:\Tomcat5527\webapps\geonetwork\/xsl/error.xsl
    2009-11-04 14:46:09,742 INFO [jeeves.service] - -> end error transformation for : mef.import
    2009-11-04 14:46:09,742 INFO [jeeves.service] - -> error ended for : mef.import
    2009-11-04 14:46:09,742 INFO [jeeves.request] - ==========================================================
    2009-11-04 14:46:09,742 INFO [jeeves.request] - HTML Request (from 127.0.0.1) : /geonetwork/srv/en/xml.user.logout
    2009-11-04 14:46:09,742 DEBUG [jeeves.request] - Method : GET
    2009-11-04 14:46:09,742 DEBUG [jeeves.request] - Content type : null
    2009-11-04 14:46:09,742 DEBUG [jeeves.request] - Accept : null
    2009-11-04 14:46:09,742 DEBUG [jeeves.request] - Session id is F08E0763DA2E8A0391219CCB56642CA0
    2009-11-04 14:46:09,742 INFO [jeeves.service] - Dispatching : xml.user.logout
    2009-11-04 14:46:09,742 DEBUG [jeeves.service] - -> no input parameters
    2009-11-04 14:46:09,742 INFO [jeeves.service] - -> dispatching to output for : xml.user.logout
    2009-11-04 14:46:09,742 INFO [jeeves.service] - -> writing xml for : xml.user.logout
    2009-11-04 14:46:09,742 DEBUG [jeeves.service] - Service xml is :
    <ok />
    2009-11-04 14:46:09,742 INFO [jeeves.service] - -> output ended for : xml.user.logout
    2009-11-04 14:46:09,742 INFO [jeeves.service] - -> dispatch ended for : xml.user.logout
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july----------------------------------------------------------------------------
GeoNetwork-devel mailing list
