[GeoNetwork-users] [GeoNetwork-devel] Thesaurus name + keywordssearch - correction
Michael,
Re. my earlier mesg.
Actually that wasn't correct what I said about entering keyword metadata in ISO19139-ANZLIC.
You can in fact enter your our own keyword OR pick from the the ANZLIC-theme
keyword list. The ANZLIC theme keyword list is stored in an XML
file in ISO CT_CodelistCatalogue format, see file attached.
Andrew
----- Original Message ----- From: "awalsh" <awalsh@anonymised.com>
To: <Michael.Stegherr@anonymised.com>
Cc: <geonetwork-users@lists.sourceforge.net>; <geonetwork-devel@lists.sourceforge.net>
Sent: Friday, December 11, 2009 5:01 PM
Subject: Re: [GeoNetwork-devel] [GeoNetwork-users] Thesaurus name + keywordssearch
Michael,
The keyword triplets that you pick from the GCMD science keyword list
get inserted into the Descriptive Keywords elements. They then become
available for search via the Advanced search page if you click in the 'Keywords'
box. So yes, they can be used for searching.
Note that this facility (can choose keyword triplets) is only
available for you entered metdata in the ISO19139 marine community profile (MCP) format.
If you entered data in say ISO19139-ANZLIC format then there isn't a keyword picker
and you just type in keywords.
To see what I mean:
1) Go to our Geonetwork site http://www.metoc.gov.au/geonetwork/
2) Select the advanced search tab
3) Click in the 'Keywords' box and start typing 'Ocean ....'
4) A list of indexed keywords (some will be triplets if from MCP records) appears in a drop down list.
5) Select one of keywords from the drop down
6) Hit the search button.
HTH,
Andrew
----- Original Message ----- From: <Michael.Stegherr@anonymised.com>
To: <awalsh@anonymised.com>
Sent: Friday, December 11, 2009 3:08 PM
Subject: RE: [GeoNetwork-devel] [GeoNetwork-users] Thesaurus name + keywordssearch
Hi Andrew,
-----Original Message-----
Sent: Friday, 4 December 2009 11:50 AM
The BlueNet-MEST version of Geonetwork (most recent stable version
20090831 is available from
http://anzlicmet.bluenet.utas.edu.au/wiki ) uses a heirarchical
keywords system but not using RDF files as in 2.4.2 GN version.
I'm aware of that system. But as far as I understand, the keyword picker is used for _entering_ metadata and not for the advanced search, which I am after. Please correct me, if I'm mistaken here.
   Michael
(attachments)
anzlic-theme.xml (41.2 KB)
