Hi Heikki Doeleman,
I cannot figure out any thing from stacktrace, as it simple ends the registration process.
The file is attached please if you could help me with it i'll be very grateful.
- Please could you also let me know that whether we can access smtp server from localhost?
- When self-registration is enabled, the banner menu functions should contain two additional choices:
‘Forgot your password?’ and ‘Register’.
In my case, only 'Register' option in the banner menu function is visible.
What could be the issue that ‘Forgot your password?’ is not visible in banner menu function.
Note:I have installed Geonetwork -2.6.4-0 on windows 7 with Service pack 1.
Kind Regards,
Saher
From: Heikki Doeleman [via OSGeo.org] <ml-node+s1560n4995673h26@anonymised.com>
To: Saher Murad <sahermurad@anonymised.com>
Sent: Thursday, 16 August 2012, 19:01
Subject: Re: Geonetwork Error for 'Enable User Self-Registration'
hi Saher,
could you check in the GeoNetwork output if you see a stacktrace, after you
do this ? This may indicate where the error occurred.
Kind regards
Heikki Doeleman
On Thu, Aug 16, 2012 at 12:59 PM, ianwallen <[hidden email]> wrote:
Saher,
You need to have the SMTP server setup properly as it send emails during
the
process. If it is not setup, self registration will not work however I did
not think it would give an error 500!
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Geonetwork-Error-for-Enable-User-Self-Registration-tp4995558p4995605.html
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
[hidden email]
[hidden email]
If you reply to this email, your message will be added to the discussion below:http://osgeo-org.1560.n6.nabble.com/Geonetwork-Error-for-Enable-User-Self-Registration-tp4995558p4995673.html
To unsubscribe from Geonetwork Error for 'Enable User Self-Registration', click here.
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/Geonetwork-Error-for-Enable-User-Self-Registration-tp4995558p4995874.html
