[GeoNetwork-users] GeoNetwork Harvest Management: BadXmlResponseEx
Dear GeoNetwork Users.
I am encountering the following error with a harvest from GeoNetwork v2.6 catalogue to a GeoNetwork v2.4.3 catalogue.
BadXmlResponseEx
[cid:image001.png@anonymised.com]
The error from our Tomcat servlet log is
2011-08-31 01:01:11,764 WARN [geonetwork.harvester] - Raised exception while harvesting from : EPA Metadata Catalog (GeonetHarvester)
2011-08-31 01:01:11,783 WARN [geonetwork.harvester] - (C) Class : BadXmlResponseEx
2011-08-31 01:01:11,783 WARN [geonetwork.harvester] - (C) Message : <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
GeoNetwork Developer
http://geonetwork-opensource.org/manuals/stable/javadoc/jeeves/jeeves/exceptions/BadXmlResponseEx.html
Do GeoNetwork users think this could be to do with the xml structure of the metadata content? Or is there something amiss with the connection settings? Alternatively, I have tried the CSW harvesting type option from the same source catalogue and this is running into troubleshooting territory aswell. I am not finding much on this online.
Kind regards.
Trevor
______________________________
Trevor Alcorn
GIS Analyst
Marine Institute, Rinville, Oranmore, Co. Galway, Ireland
Email: trevor.alcorn@anonymised.com
Ph: +353 91 387476
Fax: +353 91 387201
Online Services
(Data Discovery) Irish Spatial Data Exchange: http://www.isde.ie
(Data Discovery) Marine Data Online 2.0: http://catalog.marine.ie
(Data Request) Service: www.marine.ie/home/publicationsdata/<http://www.marine.ie/home/publicationsdata/&gt;
(Data Services) Standard Map Viewer: http://www.maps.marine.ie
This message contains confidential information and is intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission.
Is don t? at? ainmithe an teachtaireacht seo agus inte t? eolas r?nda. Muna t? an t? at? ainmithe n?or ch?ir duit an r?omhphost seo a eis-sheacada, scaipeadh n? a choip?il. M? fuir t? an r?omhphost seo tr? thimpist cur a t? a sheol ? ar an eolas l?thaireach tr? r?omhphost agus scrios ? ? do choras f?in. N? f?idir a ch?nti? go bhfuil r?omhphost gan lucht n? s?bhailte de bharr m?dh seachadadh na r?omhphost. D'fh?adfach s? go nd?anfa? tascradh ar an eolas, go mbeadh s? curtha as rocht, go gcailf? n? go scriosf? ?, go mbeadh moill ar, ? easnamhach n? go mbeadh v?reas curtha leis le linn a sheachadadh. D? bhr? sin n? glacann an t? a sheol le aon mhil?an maidir le easnaimh n? but?in in ?bhar na teachtaireachta a tharla?onn le linn a sheachadadh.
(attachments)
