[GeoNetwork-users] GeoNetwork Initialization Failed
Dear Colleagues,
I am busy building a Metadata catalogue for our GIS and remote sensing
data. I have searched the FAO implementation of the GeoNetwork and would
like to build a smaller version for our data.
I downloaded the latest release and installed with no problems, however,
after starting the server, Geonetwork fails to initialize. I downloaded and
installed the latest Java runtime environment and still receive the same
error (copied below).
The problem appears to be a permissions issue. Could someone on the list
please advise.
I am running windows 7 64 bit.
Many thanks and kind regards,
Wesley
Raised exception while initializing resource main-db in C:\Program Files
(x86)\geonetwork\web\geonetwork\WEB-INF\config.xml. Skipped.
Exception org.apache.commons.dbcp.SQLNestedException: Cannot create
PoolableConnectionFactory (IO Exception: "java.io.FileNotFoundException:
C:\Program Files (x86)\geonetwork\jetty\geonetwork.lock.db (Access is
denied)"; "C:\Program Files (x86)\geonetwork\jetty\geonetwork.lock.db"
[90031-152])
Resource main-db
Message Cannot create PoolableConnectionFactory (IO Exception:
"java.io.FileNotFoundException: C:\Program Files
(x86)\geonetwork\jetty\geonetwork.lock.db (Access is denied)"; "C:\Program
Files (x86)\geonetwork\jetty\geonetwork.lock.db" [90031-152])
Provider jeeves.resources.dbms.ApacheDBCPool
Stack org.apache.commons.dbcp.SQLNestedException: Cannot create
[90031-152])
at
org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at
org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at jeeves.resources.dbms.Dbms.connect(Dbms.java:88)
at jeeves.resources.dbms.AbstractDbmsPool.open(AbstractDbmsPool.java:142)
at jeeves.server.JeevesEngine.initResources(JeevesEngine.java:473)
at jeeves.server.JeevesEngine.loadConfigFile(JeevesEngine.java:298)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:161)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:85)
at javax.servlet.GenericServlet.init(GenericServlet.java:241)
at
org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:432)
at org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:260)
at
org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:55)
at
org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:763)
at
org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:245)
at
org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1158)
at
org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:587)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:436)
at
at
org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:36)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:180)
at
org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:479)
at
org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:136)
at
org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:137)
at
org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:50)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:494)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:406)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:355)
at org.eclipse.jetty.util.Scanner.start(Scanner.java:290)
at
org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:114)
at
at
org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:540)
at
org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:219)
at
at
org.eclipse.jetty.util.component.AggregateLifeCycle.doStart(AggregateLifeCycle.java:42)
at
org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:52)
at
org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:96)
at org.eclipse.jetty.server.Server.doStart(Server.java:258)
at
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1233)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1156)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:477)
at org.eclipse.jetty.start.Main.start(Main.java:623)
at org.eclipse.jetty.start.Main.parseCommandLine(Main.java:273)
at org.eclipse.jetty.start.Main.main(Main.java:81)
Caused by: org.h2.jdbc.JdbcSQLException: IO Exception:
at org.h2.message.DbException.getJdbcSQLException(DbException.java:327)
at org.h2.message.DbException.get(DbException.java:156)
at org.h2.message.DbException.convertIOException(DbException.java:313)
at
org.h2.store.fs.FileSystemDisk.openFileOutputStream(FileSystemDisk.java:382)
at org.h2.store.FileLock.save(FileLock.java:203)
at org.h2.store.FileLock.lockFile(FileLock.java:335)
at org.h2.store.FileLock.lock(FileLock.java:134)
at org.h2.engine.Database.open(Database.java:535)
at org.h2.engine.Database.openDatabase(Database.java:218)
at org.h2.engine.Database.<init>(Database.java:213)
at org.h2.engine.Engine.openSession(Engine.java:56)
at org.h2.engine.Engine.openSession(Engine.java:159)
at org.h2.engine.Engine.createSessionAndValidate(Engine.java:138)
at org.h2.engine.Engine.createSession(Engine.java:121)
at org.h2.engine.Engine.createSession(Engine.java:28)
at
org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:285)
at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:114)
at org.h2.jdbc.JdbcConnection.<init>(JdbcConnection.java:98)
at org.h2.Driver.connect(Driver.java:72)
at
org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at
org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at
org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at
org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
... 49 more
Caused by: java.io.FileNotFoundException: C:\Program Files
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at
org.h2.store.fs.FileSystemDisk.openFileOutputStream(FileSystemDisk.java:374)
... 68 more
"The shin bone is a device for finding furniture in a dark room."
Anon
Hi Jonathan
Please check to install outside of Program Files folder, GeoNetwork has
permission issues with this folder.
Jose García
On Fri, Mar 15, 2013 at 3:16 PM, Jonathan Roberts <gimps.sa@anonymised.com>wrote:
Dear Colleagues,
please advise.
Wesley
[90031-152])
Resource main-db
[90031-152])
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 49 more
at
... 68 more
Anon
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/&gt;
