[GeoNetwork-users] GeoNetwork IRC channel
Dear all,
Me again, sorry for the overload and possible duplications! :wink:
I set up an IRC channel so people can connect interactively to discuss GeoNetwork related issues. The channel is available on irc://irc.freenode.net/geonetwork (see http://freenode.net/).
The name of the channel is GeoNetwork
The idea is that quick questions that do not necessary need an email can be quickly discussed on IRC. No log is maintained for these conversations, so if things are better archived email is still preferred.
You need an IRC client to be able to connect. I use Colloquy on the Mac, I think many people use a client that integrates with Firefox (Chatzilla: https://addons.mozilla.org/firefox/16/) and of course you can find many other clients.
Hope this proves useful, ciao,
Jeroen
Hi Jeroen,
When we install multiple instances of geonetwork, we understnad that we
need to configure port so that there's no conflict.
How does one configure the McKoi port :
we've installed two instances
However cannot have both of them running at the same time.
Is this the problem ?
Sean
How does one change SITE ID after installation ?
sean
Hi Sean,
Please check the db.conf file in web/WEB-INF/db
Line 49 defines the JDBC port number that you need to change.
Ciao,
Jeroen
On Aug 28, 2006, at 3:04 PM, Sean Khan wrote:
Hi Jeroen,
Sean
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Sean,
Changing the SiteID after installation is not overly complex, although not the easiest thing too :slight_smile:
You will need to connect to the database using some database client (for example Druid or command line interface). In the metadata table you need to change the siteid field values for the respective metadata entries.
You also need to update the config.xml and sources.xml files (not sure if there are others, but think these are all).
Ciao,
Jeroen
sean
Hi Jeroen,
Changing the port number in the db.conf file has the following effect:
The (one) instance loads but there's no data on the page (i.e. latest
results, etc)
If we change it back to its original value, everything is back to normal.
I figured this was a cache problem so forced a reindex by clearing the
lucene directory....no difference.
My assumption at this time is that something else needs to be changed ?
sean
Sean Khan
Division of Global Environment Facility Co-ordination (DGEF)
Division of Early Warning and Assessment (DEWA)
UNEP
P.O.Box 30552
Nairobi
Fax: (254) (20) 624042
          (254)(20) 624041
Tel: (254) [20] 623271
From Europe and N.America, dial via Italy +39 0831 24 3000, wait for voice
then dial 124 3271
             Jeroen Ticheler
             <jeroen.ticheler@
             fao.org> To
                                       Sean Khan <Sean.Khan@anonymised.com>
             30/08/2006 12:16 cc
             AM geonetwork-users@anonymised.com
                                       net, Geonetwork-devel
                                       <geonetwork-devel@anonymised.com
                                       .net>
        Subject
                                       Re: [GeoNetwork-users] Multiple
                                       Instances /McKoi
Hi Sean,
Ciao,
Jeroen
Hi Jeroen,
that we
Sean
security?
job easier
Geronimo
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
You also need to rebuild indexes because th site id is indexed.
So, clean the content of the lucene folder.
Hi Sean,
metadata entries.
Ciao,
Jeroen
> sean
Hi Sean,
I discovered that McKoiDB can not run in multiple instances within the same JVM. So the configuration you try will not work. You may want to consider to use MySQL instead and create the geonetwork databases there. Otherwise you may install multiple JVMs and run each node in its own JVM. I'm not sure this is the best option...
Ciao,
Jeroen
On Aug 30, 2006, at 1:16 PM, Sean Khan wrote:
Hi Jeroen,
results, etc)
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
then dial 124 3271
             Jeroen Ticheler
             <jeroen.ticheler@
             fao.org> To
             30/08/2006 12:16 cc
                                       .net>
        Subject
                                       Instances /McKoi
Hi Sean,
Ciao,
Jeroen
Hi Jeroen,
that we
Sean
security?
job easier
Geronimo
projects/geonetwork
Thanks for this update Jeroen,
Saves us alot of time playing with proxies, etc.
Will try mysql and let you know how it goes.
Sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
then dial 124 3271
             Jeroen Ticheler
             <jeroen.ticheler@
             fao.org> To
             Sent by: Sean Khan <Sean.Khan@anonymised.com>
             geonetwork-users- cc
             bounces@anonymised.com geonetwork-users@anonymised.com
             rceforge.net net, Geonetwork-devel
                                       .net>
             30/08/2006 06:09 Subject
             PM Re: [GeoNetwork-users] Multiple
                                       Instances /McKoi
Hi Sean,
Ciao,
Jeroen
Hi Jeroen,
results, etc)
normal.
changed ?
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
for voice
then dial 124 3271
             Jeroen Ticheler
             <jeroen.ticheler@
fao.org> To
             30/08/2006
12:16 cc
             AM geonetwork-
                                       <geonetwork-
                                       .net>
Subject
                                       Instances /McKoi
Hi Sean,
Ciao,
Jeroen
Hi Jeroen,
that we
Sean
security?
job easier
Geronimo
projects/geonetwork
easier
Hi Sean,
you can start multiple instances of McKoi. This is what I did when
when I tested the harvesting. You only need one java JVM installed
(1.5) because each instance run in a different address space.
You need to change the db.conf file but also you need to change
the geonetwork's config.xml to specify a different port.
Hi Sean,
Ciao,
Jeroen
> Hi Jeroen,
> results, etc)
> normal.
> changed ?
> sean
> Sean Khan
> UNEP
> P.O.Box 30552
> Nairobi
> (254)(20) 624041
> for voice
> then dial 124 3271
> Jeroen Ticheler
> <jeroen.ticheler@
> fao.org> To
> 30/08/2006
> 12:16 cc
> AM geonetwork-
> <geonetwork-
> .net>
> Subject
> Instances /McKoi
> Hi Sean,
> Ciao,
> Jeroen
>> Hi Jeroen,
>> that we
>> Sean
>> security?
>> job easier
>> Geronimo
>> _______________________________________________
>> projects/geonetwork
GeoNetwork-devel mailing list
Dear Andrea
Appreciate if you could provide a sample of how the config.xml would
change.
I cannot find a reference to port in teh config.xml file.
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
then dial 124 3271
             Andrea Carboni
             <acarboni@anonymised.com
             s-tech.com> To
             Sent by: geonetwork-devel@anonymised.com
             geonetwork-users- net
             bounces@anonymised.com cc
             rceforge.net Sean Khan <Sean.Khan@anonymised.com>,
                                       net
             31/08/2006 01:44 Subject
                                       Instances /McKoi
             Please respond to
                 -tech.com
Hi Sean,
Hi Sean,
Ciao,
Jeroen
> Hi Jeroen,
> results, etc)
> normal.
> changed ?
> sean
> Sean Khan
> UNEP
> P.O.Box 30552
> Nairobi
> (254)(20) 624041
> for voice
> then dial 124 3271
> Jeroen Ticheler
> <jeroen.ticheler@
> fao.org> To
> 30/08/2006
> 12:16 cc
> AM geonetwork-
> <geonetwork-
> .net>
> Subject
> Instances /McKoi
> Hi Sean,
> Ciao,
> Jeroen
>> Hi Jeroen,
>> that we
>> Sean
>> security?
>> job easier
>> Geronimo
>> projects/geonetwork
easier
Geronimo
easier
Here it is:
<resource enabled="true">
  <name>main-db</name>
  <provider>jeeves.resources.dbms.DbmsPool</provider>
  <config>
    <user>admin</user>
    <password>admin</password>
    <driver>com.mckoi.JDBCDriver</driver>
    <url>jdbc:mckoi://localhost:9157/</url>
    <poolSize>4</poolSize>
  </config>
  <activator class="org.fao.geonet.activators.McKoiActivator">
    <configFile>WEB-INF/db/db.conf</configFile>
  </activator>
</resource>
You only have to change the 9157 port to some other value (maybe 9158).
Dear Andrea
change.
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
then dial 124 3271
             Andrea Carboni
             s-tech.com> To
                                       net
                                       Instances /McKoi
             Please respond to
                 -tech.com
Hi Sean,
> Hi Sean,
> Ciao,
> Jeroen
> > Hi Jeroen,
> > results, etc)
> > normal.
> > changed ?
> > sean
> > Sean Khan
> > UNEP
> > P.O.Box 30552
> > Nairobi
> > (254)(20) 624041
> > for voice
> > then dial 124 3271
> > Jeroen Ticheler
> > <jeroen.ticheler@
> > fao.org> To
> > 30/08/2006
> > 12:16 cc
> > AM geonetwork-
> > <geonetwork-
> > .net>
> > Subject
> > Instances /McKoi
> > Hi Sean,
> > Ciao,
> > Jeroen
> >> Hi Jeroen,
> >> that we
> >> Sean
> >> security?
> >> job easier
> >> Geronimo
> >> projects/geonetwork
easier
Geronimo
easier
Dear Andrea,
We're getting somewhere and I will create a How to/FAQ on the community
site when this is all over:
Changing the port in the db.conf file and specifying the new one in
config.xml resolve the single instance starting and reflecting data.
Howeer, there still a conflict with the port which I can't figure out.
See below:
java.net.BindException: Address already in use
WARN: Not listening on monitor port: 8079
16:26:22.422 INFO [main] org.mortbay.log.LogImpl.add(LogImpl.java:109)
16> added org.mortbay.log.OutputStreamLogSink@anonymised.com
16:26:22.357 INFO [main]
org.mortbay.util.FileResource.<clinit>(FileResource.java:60) >11> Checking
Resource aliases
Any insight here ?
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
then dial 124 3271
             Andrea Carboni
             s-tech.com> To
             rceforge.net net,
                                       net
             31/08/2006 04:00 Subject
                                       Instances /McKoi
             Please respond to
                 -tech.com
Here it is:
             <config>
                         <user>admin</user>
             </config>
             </activator>
</resource>
Dear Andrea
change.
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
voice
then dial 124 3271
             Andrea Carboni
             s-tech.com>
To
             Sent by:
cc
                                       net
             31/08/2006 01:44
Subject
                                       Instances /McKoi
             Please respond to
                 -tech.com
Hi Sean,
> Hi Sean,
> Ciao,
> Jeroen
> > Hi Jeroen,
effect:
> > results, etc)
> > normal.
the
> > changed ?
> > sean
> > Sean Khan
> > UNEP
> > P.O.Box 30552
> > Nairobi
> > (254)(20) 624041
> > for voice
> > then dial 124 3271
> > Jeroen Ticheler
> > <jeroen.ticheler@
> > fao.org> To
> > 30/08/2006
> > 12:16 cc
> > AM geonetwork-
> > <geonetwork-
> > .net>
> > Subject
Multiple
> > Instances /McKoi
> > Hi Sean,
> > Ciao,
> > Jeroen
> >> Hi Jeroen,
> >> that we
> >> Sean
> >> security?
> >> job easier
> >> Geronimo
> >> projects/geonetwork
security?
easier
Geronimo
easier
Geronimo
easier
Hi Sean,
I think that you are trying to run 2 jettys on the same port. Try to edit the
bin/jetty.xml file and choose a port other than 8080.
You also need to change the bin/start-geonetwork and bin/stop-geonetwork
scripts to change the STOP.PORT. If you use the same port when you stop
one geonetwork the other will be stopped too.
Dear Andrea,
See below:
Resource aliases
Any insight here ?
sean
Sean Khan
UNEP
P.O.Box 30552
Nairobi
          (254)(20) 624041
then dial 124 3271
             Andrea Carboni
             s-tech.com> To
             rceforge.net net,
                                       net
                                       Instances /McKoi
             Please respond to
                 -tech.com
Here it is:
             <config>
                         <user>admin</user>
             </config>
             </activator>
</resource>
> Dear Andrea
> change.
> sean
> Sean Khan
> UNEP
> P.O.Box 30552
> Nairobi
> (254)(20) 624041
voice
> then dial 124 3271
> Andrea Carboni
> s-tech.com>
To
> Sent by:
cc
> net
> 31/08/2006 01:44
Subject
> Instances /McKoi
> Please respond to
> -tech.com
> Hi Sean,
> Cheers,
> Andrea
> > Hi Sean,
> > Ciao,
> > Jeroen
> > > Hi Jeroen,
effect:
> > > results, etc)
> > > normal.
the
> > > changed ?
> > > sean
> > > Sean Khan
> > > UNEP
> > > P.O.Box 30552
> > > Nairobi
> > > (254)(20) 624041
> > > for voice
> > > then dial 124 3271
> > > Jeroen Ticheler
> > > <jeroen.ticheler@
> > > fao.org> To
> > > 30/08/2006
> > > 12:16 cc
> > > AM geonetwork-
> > > <geonetwork-
> > > .net>
> > > Subject
Multiple
> > > Instances /McKoi
> > > Hi Sean,
> > > Ciao,
> > > Jeroen
> > >> Hi Jeroen,
> > >> that we
> > >> Sean
> > >> security?
> > >> job easier
> > >> Geronimo
> > >> projects/geonetwork
security?
> easier
> Geronimo
> easier
Geronimo
easier
