[GeoNetwork-users] Geonetwork - Javascript error when adding new record
Since two years, we are using Geonetwork 2.10 in our Spatial Data Infrastructure based on Georchestra solution.
We are testing the last release of our SDI integrating Geonetwork 3.0.4 and we have some trouble when clicking on “Add new record”, a blank page is displayed and some Javascript errors occurs.
To note, when we are in debug mode (add parameter ?debug), the page is displayed and we can had new record.
Navigator console
SyntaxError: expected expression, got ‘<’
Error: [$injector:nomod] http://errors.angularjs.org/1.3.4/$injector/nomod?p0=gn_editor
gn_editor.js
302 Found
Found
The document has moved here.
302 Found
Found
302 Found
Found
302 Found
Found
302 Found
Found
302 Found
Found
(function() {angular.module(‘gn’).run([‘$templateCache’, function($templateCache) {
$templateCache.put(‘…/…/catalog/components/common/popup/partials/popup.html’, ‘
{{options.title}}
$templateCache.put(‘…/…/catalog/components/search/facets/partials/facet-list.html’, ‘
’);$templateCache.put(‘…/…/catalog/components/search/facets/partials/facet-multiselect.html’, ‘
{{facetConfig.label | translate}}
{{f['@label'] || f['@name']}}  ({{f['@count']}})
’);$templateCache.put(‘…/…/catalog/components/search/facets/partials/dimension-facet-list.html’, ‘
{{f['@label'] | translate}}
’);$templateCache.put(‘…/…/catalog/components/search/facets/partials/facet-item.html’, ‘
{{facet}}
{{f['@count']}}{{f['@label'] || f['@name']}} {{facetResults[facet].length-initialMaxItems}} {{ (facetResults[facet].length >= maxItems) ? ('more' | translate) : ('less' | translate) }}
’);$templateCache.put(‘…/…/catalog/components/search/facets/partials/facet-breadcrumb.html’, ‘’);$templateCache.put(‘…/…/catalog/components/search/facets/partials/dimension-facet-category.html’, '
  • <span data-ng-
    Thanks for your help.
    Best regards
    Rémi EVE
    SDI Guyane SIG
