[GeoNetwork-users] Geonetwork manual for centos 5.2 problem
Dear Pedro Monteiro,
Surely now am almost confused but before i get totally confused may be you
could sort me out
I have been working with centos 5.2
1. I have been installing java jdk-6u14-ea-bin-b03-linux-i586-10.bin
which out put this as the version installed as the default 1.6.0_14-ea
2. I have also been installing tomcat5 through yum install tomcat5
which have been installing very well as i can been able to start and stop it
3. I have been installing Geonetwork version 2.2.0 which have been
installing some how well but have never configured MSQL database with GAST
After this the only file that i do configure is the server.xml for the
tomcat5 under host i normally fix the content for geonetwork , Geoserver and
for intermap
After this i normally set tomcat to start as a service with the chkconfig
command
but when i try to launch my geonetwork on this
http://66.96.201.221:8080/geonetwork it never come
i surely don't what have not been configured upto now
looking for your advice
Regards
simon
----- Original Message -----
From: "Pedro Monteiro" <monteiro.s.pedro@anonymised.com>
To: "simon .K.M" <simon@anonymised.com>
Cc: <geonetwork-users@lists.sourceforge.net>
Sent: Friday, April 17, 2009 1:26 PM
Subject: Re: [GeoNetwork-users] Geonetwork manual for centos 5.2
Hello
I've configured on server with geonetwork. What kind of problems are you
having?
2009/4/17 simon .K.M <simon@anonymised.com>
Dear all,
Is there anybody who have ever configured geonetwork on centos5.2.
regards
Web Designer
ERMIS Africa
P.O. Box 17347
Nakuru-20100
Kenya
Tel:254-51-2213323
Fax:254-51-2214536
Cell Phone +254 725 885 889
E-mail:simon@anonymised.com <E-mail%3Asimon@anonymised.com>
Website:http://www.ermisafrica.org
http://www.ermisafrica.com
Stay on top of everything new and different, both inside and
around Java (TM) technology - register by April 22, and save
$200 on the JavaOne (SM) conference, June 2-5, 2009, San Francisco.
300 plus technical and hands-on sessions. Register today.
Use priority code J9JMT32. http://p.sf.net/sfu/p
GeoNetwork-users mailing list
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.238 / Virus Database: 270.11.59/2064 - Release Date: 04/17/09
07:08:00
Well I've never managed to get it working with the tomcat rpm package, as it
uses gcj and gives some problems.
Try a tomcat install as explained in
http://geoserver.org/display/GEOSDOC/1.1.4+CentOS+(Red+Hat)+5.1+Install.
Hope it helps,
2009/4/17 <sysadmin@anonymised.com>
could sort me out
it
and
for intermap
command
Regards
simon
> Hello
> having?
>> Dear all,
>> regards
>> Web Designer
>> ERMIS Africa
>> P.O. Box 17347
>> Nakuru-20100
>> Kenya
>> Tel:254-51-2213323
>> Fax:254-51-2214536
>> E-mail:simon@anonymised.com <E-mail%3Asimon@anonymised.com> <
E-mail%3Asimon@anonymised.com <E-mail%253Asimon@anonymised.com>>
>> _______________________________________________
07:08:00
Hey Pedro,
Tomcat now looks to respond to the port 8080 that is on this link
http://66.96.201.221:8080 but as soon as i have installed Geonetwork and
installed very well and configured tomcat file SERVER.XML where i have
fixed the path for Geonetwork,Geoserver and intermap that is within host
element BUT when i try to browse this http://66.96.201.221:8080/geonetwork
IT SEEM NOT TO GO ANYWHERE and EVEN TOMCAT HAS GONE OFF(not showing).
bUT i have noticed a echo from the shell as follow
/opt/java/jdk1.6.0_14/bin/java -jar geonetwork-install-2.2.0.j
    ar
Exception in thread "AWT-EventQueue-0"
javax.swing.text.StateInvariantError: Gly phView: Stale
view: javax.swing.text.BadLocationException: Length must be positi
        ve
        at javax.swing.text.GlyphView.getText(GlyphView.java:118)
        at
javax.swing.text.GlyphView.getBreakSpotUseWhitespace(GlyphView.java:7
                40)
        at javax.swing.text.GlyphView.getBreakSpot(GlyphView.java:732)
        at javax.swing.text.GlyphView.getBreakWeight(GlyphView.java:670)
        at
javax.swing.text.html.InlineView.getBreakWeight(InlineView.java:136)
        at
javax.swing.text.FlowView$FlowStrategy.layoutRow(FlowView.java:508)
        at javax.swing.text.FlowView$FlowStrategy.layout(FlowView.java:460)
        at javax.swing.text.FlowView.layout(FlowView.java:184)
        at javax.swing.text.BoxView.setSize(BoxView.java:380)
        at javax.swing.text.BoxView.updateChildSizes(BoxView.java:349)
        at javax.swing.text.BoxView.setSpanOnAxis(BoxView.java:331)
        at javax.swing.text.BoxView.layout(BoxView.java:691)
        at
javax.swing.plaf.basic.BasicTextUI$RootView.setSize(BasicTextUI.java:
                1702)
        at
javax.swing.plaf.basic.BasicTextUI$RootView.paint(BasicTextUI.java:14
                21)
        at
javax.swing.plaf.basic.BasicTextUI.paintSafely(BasicTextUI.java:722)
        at javax.swing.plaf.basic.BasicTextUI.paint(BasicTextUI.java:869)
        at javax.swing.plaf.basic.BasicTextUI.update(BasicTextUI.java:848)
        at javax.swing.JComponent.paintComponent(JComponent.java:763)
        at javax.swing.JComponent.paint(JComponent.java:1029)
        at javax.swing.JComponent.paintChildren(JComponent.java:864)
        at javax.swing.JComponent.paint(JComponent.java:1038)
        at javax.swing.JViewport.paint(JViewport.java:747)
        at javax.swing.JComponent.paintToOffscreen(JComponent.java:5124)
        at
javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManag
                er.java:277)
        at javax.swing.RepaintManager.paint(RepaintManager.java:1220)
        at javax.swing.JComponent._paintImmediately(JComponent.java:5072)
        at javax.swing.JComponent.paintImmediately(JComponent.java:4882)
        at
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:803)
        at
javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:714)
        at
javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:6
                94)
        at
javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(System
                EventQueueUtilities.java:128)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
        at
java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThre
                ad.java:269)
        at
java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.
                java:184)
        at
java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThre
                ad.java:174)
        at
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
        at
java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Am wondering if Java is the one that has a PROBLEM OR IS THE tOMCAT that
is not fully configured against Geonetwork.
Is there anybody with a way forward.
Regard
Simon
it
Hope it helps,
you
could sort me out
stop
it
GAST
and
for intermap
chkconfig
command
Regards
simon
> Hello
you
> having?
>> Dear all,
>> regards
>> Web Designer
>> ERMIS Africa
>> P.O. Box 17347
>> Nakuru-20100
>> Kenya
>> Tel:254-51-2213323
>> Fax:254-51-2214536
04/17/09
07:08:00
Hey Pedro,
    ar
        ve
        at
                40)
        at
        at
        at
                1702)
        at
                21)
        at
        at
                er.java:277)
        at
        at
        at
                94)
        at
        at
                ad.java:269)
        at
                java:184)
        at
                ad.java:174)
        at
        at
Regard
Simon
it
Hope it helps,
you
could sort me out
stop
it
GAST
and
for intermap
chkconfig
command
Regards
simon
> Hello
you
> having?
>> Dear all,
>> regards
>> Web Designer
>> ERMIS Africa
>> P.O. Box 17347
>> Nakuru-20100
>> Kenya
>> Tel:254-51-2213323
>> Fax:254-51-2214536
04/17/09
07:08:00
