[GeoNetwork-users] Geonetwork - migrate database (postgreSQL) from 2.4.2 to 2.6.3
Hi folks,
Is there a sql script (postgreSQL)which allows me to migrate the database from version 2.4.2 to 2.4.3?
I am currently using version 2.4.2.
For testing I have installed the new version 2.6.3with new database. Now I want to keep my old data.
I find a migration tool (a sql script) which allows me to migratethe database from version 2.4.3 to version 2.6.3. But how do I get from version 2.4.2 to version 2.4.3?
Can someone help me how I get my system up to date?
Regards Maik
Hi Maik
You'll need to check if any database schema differences in
INSTALL_DIR/gast/sql/create-db-XXXX.sql between 2.4.2 and 2.4.3
For data, check differences in INSTALL_DIR/gast/db/*.ddf files between 2.4.2
and 2.4.3. No sql scripts for data.
Jose GarcĂ­a
On Wed, Mar 9, 2011 at 2:53 PM, Maik Wannink <maik.wannink@anonymised.com
wrote:
Hi folks,
Regards Maik
Colocation vs. Managed Hosting
A question and answer guide to determining the best fit
for your organization - today and in the future.
http://p.sf.net/sfu/internap-sfd2d
GeoNetwork-users mailing list
