Dear colloeagues, we have install Geonetwork 3.10.2.0.
We generate our metadatas outside Geonetwork, we load them in Geonetwork and when we export a metadata as a XML, the metadata has been changed by Geonetwork.
Geonetwork adds the namespace geonet reference in every element and it changes the trilingual structure in every trilingual element. It happens the same when we want to see the metadatas in Geonetwork in the XML option
We want our metadata to be seen and export as we create them without any changes. Do you know what should we change in Geonetwork configuration? Thank you!
Here you are a piece of the original xml
this is the same piece when the metadata has been exported from Geonetwork.
Hi Margarita
There's a fix for the geonet namespace, see
https://github.com/geonetwork/core-geonetwork/pull/4825, should be
available in the next version 3.10.4.
Jose García
On Fri, Jul 3, 2020 at 1:28 PM Margarita Caletrio Arcos <caletrio_mar@anonymised.com...>
Geonetwork.
Thank you!
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
