[GeoNetwork-users] Geonetwork on Oracle
I'm trying to install Geonetowrk using an Oracle XE edition.
I'm using GAST for purpose. I suppose I have to make an export (Management à Export) end then an Import on the configured Oracle DB (Configuration à DBMS).
However when I try to make the export, I receive the error message "host must not be null".
I don't uderstand where the host must be specified. In the DBMS configuration for the embedded DB there is no host, and for Oracle I specified "localhost".
Can someone help me on the correct procedure to use Geonetowrk on Oracle DB ?
Thans in advance
Piero
