Date: 22 October 2013
We're pleased to announce the release v2.10.2 of GeoNetwork opensource. This is a minor release that includes bug fixes discovered in earlier versions.
Proceed to Download GeoNetwork — GeoNetwork opensource and enjoy!
Thanks and congratulations to the all community members!
Jeroen Ticheler
Here's an overview of fixes to this version:
• #267 HTML5 UI: Use WMC context in map and allow OSM layers
• #271 Transfer ownership displays target users repeated
• #266 HTML5 UI: Hide special groups from New Metadata panel
• Merge pull request #265 from Delawen/origin/2.10.x
• Fixing a really weird bug on IE I don't even know how to report.
• Merge pull request #263 from Delawen/136
• Check if we passed an override parameter for layers #136
• Merge pull request #227 from kristjanr/PressingEnterKeyWhenSearching
• #257 WMS harvester thumbnail issue (classic UI)
• Merge remote-tracking branch 'origin/2.10.x' into 2.10.x
• Editor / XML view / Do not escape (#254).
• #247 HTML5 UI: Context menu in search results displaying admin options when unlogged
• Fix email size for group - live fix from GeoNetwork workshop in FOSS4G2013.
• #246 HTML5 UI: Click on search result metadata title doesn't open the metadata detail page
• #241 Fix MySql create sql script
• Merge pull request #220 from ianwallen/Branch_a6a1b2af565d7e159c4a644e8c82475063912773
• Merge pull request #221 from ianwallen/Fix_Issue_174
• Fixed issue when the referer was null
• Merge pull request #173 from ianwallen/Jetty-7.6.8
• Fix issue 213 Fixed issues related to last commit (dcd363f2cb8cbb08a0113a370c0fcc506061aa8b) - characterset issue with ita - commited conflict info from nor
• Fix bug edit linkresource service selection
• Widgets / Editor / User defined frequency is not properly saved.
____________________________________________________
GeoCat introduces Bridge©
An extension to ArcGIS© to instantly publish data and metadata on GeoServer and GeoNetwork.
See http://geocat.net for more details.
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31 (0)6 81286572
Please consider the environment before printing this email.
