[GeoNetwork-users] Geonetwork Port
Hi guys,
I am running tomcat 8 on my VM and I recently deployed a geoserver on the same machine on which my geonetwork runs. Since then the geonetwork does not work anymore. Do I need to change the default port 8080 to some other or can those two applications coexist with the same port number? If not, where do I have to change this for my geonetwork?
Thanks and regards
Andreas
Hello Andreas,
On Tue, Oct 6, 2020 at 3:56 PM Andreas Böhme <andreas.boehme@anonymised.com> wrote:
Hi guys,
They can coexist if you deploy them in the same Tomcat server.
If each one is deployed in a different Tomcat server you will need to
change the port of one of them to something different than 8080. This is a
setting of Tomcat itself, not GeoNetwork. Check [1] to read about how to
change it. If you are not going to use an Apache or NGINX server in front
of Tomcat you will need to tune GeoNetwork settings for Port and Secure
Port [2].
[1] https://mkyong.com/tomcat/how-to-change-tomcat-default-port/
[2]
https://www.geonetwork-opensource.org/manuals/trunk/en/tutorials/introduction/setup/index.html#basic-settings
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hola Juan,
thanks for your answer. My situation is: Ubuntu 18 with tomcat 8.5.39 and inside I run a geoserver 2.17 and I am trying to bring my geonetwork 3.10.2 back to live. I also have another application in a tomcat9 environment (port 8081). The tomcat 8 is on port 8080. Geoserver and other app are working fine. I use a local postgres DB for my geonetwork. I just deleted all old geonetwork databases and set up a fresh geonetwork and database and I always get this error:
The origin server did not find a current representation for the target resource or is not willing to disclose that one exists. This results in a 404 error. I must have something to do with my web.xml file, right? I have no clue what to do so any advice would be appreciated.
many thx and regards
Andreas
Am 06.10.2020 um 18:34 schrieb Juan Luis Rodríguez Ponce:
Hello Andreas,
On Tue, Oct 6, 2020 at 3:56 PM Andreas Böhme <andreas.boehme@anonymised.com.. <mailto:andreas.boehme@anonymised.com>> wrote:
    Hi guys,
    geonetwork
    to some
    number?
If each one is deployed in a different Tomcat server you will need to change the port of one of them to something different than 8080. This is a setting of Tomcat itself, not GeoNetwork. Check [1] to read about how to change it. If you are not going to use an Apache or NGINX server in front of Tomcat you will need to tune GeoNetwork settings for Port and Secure Port [2].
[2] https://www.geonetwork-opensource.org/manuals/trunk/en/tutorials/introduction/setup/index.html#basic-settings
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664 <tel:+31318416664>
Please consider the environment before printing this email.
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
andreas.boehme@anonymised.com, www.ufz.de
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
