[GeoNetwork-users] Geonetwork & PostgreSQL/PostGIS
Hello everyone.
I installed GeoNetwork 2.6.4 on windows 7. Now a few questions:
- According to the documentation several packages should be included in the installer file. I only have the possibility to install the core package - nothing else, no choice.
- How can I use a PostgreSQL db instead McKOI db? In this matter, the documentation tells me to use GAST (which btw looks completely different on my system than in the documentation). Do I only have to connect to the db-conf of postgresql? I'm looking for an easy way to solve this problem since I'm not that familiar with dbs.
- Last but not least: I thought that GeoServer is embedded in GeoNetwork. I could find a geoserver.war file but it wasn't possible to use GeoServer as map viewer. I downloaded the .war file again from the hp again. Now it looks at least like GeoServer does something since I get some error messages.
Is it possible to add packages after installation or doesn't it sound like I'm missing something?
I would appreciate every response. Cheers,
Michael
In the geonetwork.war there is no option to install parts, there's only the
GeoNetwork-server included.
Read here from slide 12 how to use PostgreSQL:
http://geonetwork-opensource.org/_static/foss4g2010/FOSS4G_Mastering_Advanced_GeoNetwork.pdf
In the geonetwork.war there is also no GeoServer included, only in the
standalone-version with jetty everything is pre-configured. You'll even need
to fix the config-gui.xml to fix the default from this installation.
Geomatics Lab | Geography Department | Humboldt-Universitaet zu Berlin
web: http://www.hu-geomatics.de
View this message in context: http://osgeo-org.1560.n6.nabble.com/Geonetwork-PostgreSQL-PostGIS-tp3860331p4332213.html
