Hello everyone,
I want to set up Geonetwork (2.6.4 on Windows XP) for a specific country and try to adapt the drop-down-menu for the countries in the search function. The default db handling with mckoi is insufficient for me, so I want to use PostgreSQL for the database stuff.
I followed the instructions in the link (http://geonetwork-opensource.org/_static/foss4g2010/FOSS4G_Mastering_Advanced_GeoNetwork.pdf), but after configuration the drop-down-menu shows only the values '- Any -' and '- User defined -'. Furthermore, the application categories in the left menu are missing.
When I open the database geonetwork with pgAdmin, there are 25 tables including regions and regionsdes. Those look exactly like the basic tables in mckoi. Does anybody know a solution?
D. Stroeer
##### config.xml #####
<resource enabled="true">
<name>main-db</name>
<provider>jeeves.resources.dbms.DbmsPool</provider>
<config>
<user>geonetwork</user>
<password>geonetwork</password>
<driver>org.postgresql.Driver</driver>
<url>jdbc:postgresql://127.0.0.1/geonetwork</url>
<poolSize>10</poolSize>
</config>
</resource>
##### pg_hba.conf #####
# IPv4 local connections:
host all all 127.0.0.1/32 md5
Hi Dennis
Please check the log files, if categories are not displayed seems a
database connection issue.
Seem from what you say that tables are in the database, can you verify also
if tables contain data?
Jose García
On Fri, May 11, 2012 at 4:50 PM, Dennis Ströer
<dennis.stroeer@anonymised.com>wrote:
Hello everyone,
D. Stroeer
<config>
</config>
</resource>
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Am 11.05.2012 17:18, schrieb Jose Garcia:
Hi Dennis
Please check the log files, if categories are not displayed seems a database connection issue.
Seem from what you say that tables are in the database, can you verify also if tables contain data?
Jose García
On Fri, May 11, 2012 at 4:50 PM, Dennis Ströer <dennis.stroeer@anonymised.com <mailto:dennis.stroeer@anonymised.com>> wrote:
Hello everyone,
country
me, so
'- Any
D. Stroeer
<config>
<http://127.0.0.1/geonetwork></url>
</config>
</resource>
host all all 127.0.0.1/32 <http://127.0.0.1/32> md5
Discussions
malware
<mailto:GeoNetwork-users@lists.sourceforge.net>
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net/> for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Hello Jose,
thanks for your advice. The log file contained a reference for the solution. The owner of the new database was correct but the owner of the single tables was wrong! After changing that, everything works fine.
D. Stroeer
