[GeoNetwork-users] Geonetwork + Postgresql
Dear Readers
I try to import a MEF into a postgresql db and I get back the message:
"You need to authenticate"
Well, I have created a db in postgresql named "geonetwork"
Then I have have defined the db in the GAST tool: DBMS Configuration
[DBMS: PosteSQL
Server: localhost
Port: 5432
Database: geonetwork
User Name: coast
Password: coast
I run the GAST tool: Database Setup (everything till now run ok)
When I try to Import the sample data I get the error message
Any help / suggestion would be greatly appreciated. I granted also
priviledges to the user in postresql
Thanks in advance!
Emmanuel.
Dear Emmanuel,
You have to give a user/password combination that is valid for the GeoNetwork application itself, not the database user. So you could first try to use the administrator account (by default admin/admin ). Through the web interface you can create other users with at a minimum the editor profile in order to be allowed to import MEF files.
Hope this helps and that I correctly understood your problem.
Greetings,
Jeroen
On Feb 29, 2008, at 10:15 AM, E.Stefanakis wrote:
Dear Readers
[DBMS: PosteSQL
Server: localhost
Port: 5432
User Name: coast
Password: coast
Thanks in advance!
Emmanuel.
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
