[GeoNetwork-users] GeoNetwork rarely starts
I'm using OsGeoLive 10.0 with virtualBox (on Windows 8.1 machine). When I
try to start geonetwork (using the link "Start GeoNetwork" inside the
desktop folder "Web Services"), I wait a minute and then, when firefox
opens, I always get an error (the classical error like there's no
connection, and tells to try reloading the page). If I keep trying reloading
the page for 4/5 times, then this error appears:
HTTP ERROR: 503
Problem accessing /geonetwork/. Reason:
    Service Unavailable
Powered by Jetty://
<http://osgeo-org.1560.x6.nabble.com/file/n5323416/_geonetwork_error.png&gt;
This error happens to me a lot of times. Rarely geonetwork starts correctly.
I have tried also starting it from the command line and the result is this:
root@anonymised.com:/usr/local/lib/geonetwork/bin# ./startup.sh
rm: cannot remove 'logs/*request.log*': No such file or directory
mv: cannot stat 'logs/geonetwork.log.*': No such file or directory
mv: cannot stat 'logs/geoserver.log.*': No such file or directory
** (zenity:3648): WARNING **: Error retrieving accessibility bus address:
org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not
provided by any .service files
Gtk-Message: GtkDialog mapped without a transient parent. This is
discouraged.
*I have tried re-creating from scratch a new virtual machine with osgeolive,
but the error still persists
*Trying from the command line or by clicking the "start geonetwork" link,
it's the same, the problem still persists.
*The problem doesn't happen with geoserver, that always starts correctly.
*I'm always conneted to the internet when I start it
#I suspect (I would ask) if this problem could depend both on the quality of
the connection and the hardware of the notebook. Some colleagues have the
same problem but with a lower intensity than me. Most of the times (2 times)
that geonetwork could start wasn't at home. I think also a good hardware
could help. I have 4 gb of ram, AMD A6 6310 apu (1,60Ghz), Amd Radeon R4
graphics, and I run osgeolive in virtualbox dedicating 1200 mb of RAM.
Is there a solution that could help?
Thank you very much for your time and consideration.
Best
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-rarely-starts-tp5323416.html
Although OSGeo-Live 10.0 lists 1.0 GB of RAM as minimum requirement, GeoNetwork requires much more to run properly.
This is why we have added a hint in that section of our download page: https://live.osgeo.org/en/download.html
Angelos
On 06/07/2017 11:27 PM, userdrake wrote:
HTTP ERROR: 503
     Service Unavailable
Powered by Jetty://
discouraged.
Best
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
Hello everybody
I would like to install Geonetwork and Geoserver on Ubuntu 16.04 LTS - I would like to use a Postgres 9.6 database with Postgis 2.3.
I want to work on Postgres and Postgis, because I will use large raster data in the end.
Is there a step by step guide to install Geonetwork and Geoserver and start it with Jetty?
I found this Website http://demo.geo-solutions.it/share/bev/doc/index.html .
Can you help me there?
Best regards
Robert
Hi
Installing the installer in a linux without graphical environment is
possible. See this section:
http://geonetwork-opensource.org/manuals/2.10.4/eng/users/quickstartguide/installing/index.html#commandline-installation
It's for 2.10 version, as seem not migrated to the 3.x documentation, but
should be valid for 3.x installers.
What I do usually is to install the installer in OSX or Windows and at the
end of the process the installer gives the option to save the installer
steps in install.xml file, that can use later in the linux server as
described in previous link.
Related to the database, check this section
http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/configuring-database.html#configuring-the-database,
to edit the described files to enable Postgis, although documentation is
not very good.
Jose García
On Thu, Jun 8, 2017 at 2:52 PM, Robert k <kwo_bo@anonymised.com> wrote:
Hello everybody
data in the end.
Best regards
Robert
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
I have the same issue with OSGeoLive 11.0 using HyperV/WinServer2016. Last
week I startet it the first time, did some updates and Geonetwork did start.
Now it gives me the same error message userdrake has. I got the blank 11.0
again, in a new VM and had the same problem again. Geoserver is working,
Geonetwork not. Then I gave the machine 12 GB RAM and two cpu. Same problem.
It does not start anymore.
Did you got any new idea?
Greetings
Drongo
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
