[GeoNetwork-users] GeoNetwork SMTP configuration problems
Hi
I can't get Feedback or sending WMC to work in GN as I'm struggling to
configure my smtp server. GN config only accepts smtp server and port
and no authentication options.
I have access to a secure smtp server only (gmail) so I need to supply
username and password credentials as well as indicate that
authentication is required, but there are no options for these in
GeoNetwork config.
Any way around this?
Geonetwork 2.4 on Tomcat 6 / Postgresql8.4 / Win server 2003.
thanks
Gavin
subscribing
same problem here. any solutions?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GeoNetwork-SMTP-configuration-problems-tp4881049p6792627.html
Hi Gavin,
M facing the same problem as u reported, did u find any solution to it?
Any help would be highly appreciated.
Thank you,
Saher
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoNetwork-SMTP-configuration-problems-tp3860565p5028991.html
