Hi
I have installed Geonetwork 2.8 and tried to start the server using the icon from the start menu, the script in the cmd window ran but it then disappeared. After checking the Geonetwork home page the editor did not appear.
Below is my log file, is there anything that suggests why the server did not start correctly?
Thanks
2013-07-30 16:35:12,815 WARN [jeeves.dbmspool] - Using transaction isolation setting READ_COMMITTED 2013-07-30 16:35:14,707 INFO [jeeves.apphand] - Initializing GeoNetwork 2.8.0.0 ...
2013-07-30 16:35:14,707 WARN [geonetwork.data.directory] - - Data directory initialization: null
2013-07-30 16:35:14,707 WARN [geonetwork.data.directory] - - Data directory properties is not set. Use geonetwork.dir or geonetwork.dir properties.
2013-07-30 16:35:14,707 WARN [geonetwork.data.directory] - - Data directory provided could not be used. Using default location: C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\
2013-07-30 16:35:14,707 INFO [jeeves.apphand] - Data directory: C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\
2013-07-30 16:35:14,707 INFO [jeeves.apphand] - jeeves.xml.catalog.files property set to C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\oasis-catalog.xml;C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\config\schemaplugin-uri-catalog.xml
2013-07-30 16:35:14,707 INFO [jeeves.apphand] - Overriding mime-mappings property (was set to ..\web\geonetwork\WEB-INF\mime-types.properties)
2013-07-30 16:35:14,707 INFO [jeeves.apphand] - mime-mappings property set to C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\mime-types.properties
2013-07-30 16:35:14,863 INFO [jeeves.apphand] - - Database connection on jdbc:h2:geonetwork;LOCK_TIMEOUT=20000;MVCC=TRUE ...
2013-07-30 16:35:14,879 INFO [jeeves.apphand] - Found an existing GeoNetwork database.
2013-07-30 16:35:14,879 INFO [jeeves.apphand] - - Thread Pool...
2013-07-30 16:35:14,879 INFO [jeeves.apphand] - - Setting manager...
2013-07-30 16:35:14,894 INFO [jeeves.apphand] - - Migration ...
2013-07-30 16:35:14,894 INFO [jeeves.apphand] - Webapp version:2.8.0 subversion:0
2013-07-30 16:35:14,894 INFO [jeeves.apphand] - Database version:2.8.0 subversion:0
2013-07-30 16:35:14,894 INFO [jeeves.apphand] - Webapp version = Database version, no migration task to apply.
2013-07-30 16:35:14,894 INFO [jeeves.apphand] - - Z39.50...
2013-07-30 16:35:14,910 WARN [jeeves.apphand] - Cannot initialize Z39.50 repositories : C:\Program%20Files%20(x86)\geonetwork\web\geonetwork\WEB-INF\classes\JZKitConfig.xml.tem (The system cannot find the path specified)
2013-07-30 16:35:14,941 ERROR [jeeves.apphand] - Repositories file builder FAILED - Z3950 server disabled and Z3950 client services (remote search, harvesting) may not work.
2013-07-30 16:35:14,941 INFO [jeeves.apphand] - - Schema manager...
2013-07-30 16:35:14,941 INFO [jeeves.apphand] - - Schema plugins directory: C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\config\schema_plugins
2013-07-30 16:35:14,941 INFO [jeeves.apphand] - - Schema Catalog File : C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\config\schemaplugin-uri-catalog.xml
2013-07-30 16:35:15,050 DEBUG [jeeves] - Using oasis catalog files C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\oasis-catalog.xml;C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\config\schemaplugin-uri-catalog.xml
2013-07-30 16:35:15,050 DEBUG [jeeves] - Using catalog resolver verbosity 1 2013-07-30 16:35:18,248 DEBUG [jeeves] - Using oasis catalog files C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\oasis-catalog.xml;C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\config\schemaplugin-uri-catalog.xml;C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\config\schema_plugins\iso19139/oasis-catalog.xml
2013-07-30 16:35:18,264 DEBUG [jeeves] - Using catalog resolver verbosity 1
2013-07-30 16:35:18,264 INFO [jeeves.apphand] - - Search...
2013-07-30 16:35:18,264 INFO [jeeves.apphand] - - Log spatial object: false
2013-07-30 16:35:18,264 INFO [jeeves.apphand] - - Log in asynch mode: true
2013-07-30 16:35:18,279 INFO [jeeves.apphand] - - Lucene configuration is:
2013-07-30 16:35:18,295 INFO [jeeves.apphand] - Lucene configuration:
* Version: LUCENE_36
* RAMBufferSize: 48.0
* MergeFactor: 10
* Default analyzer: org.fao.geonet.kernel.search.GeoNetworkAnalyzer
* Field analyzers: {hassource=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, parentUuid=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, _groupPublished=org.apache.lucene.analysis.KeywordAnalyzer, subject=org.apache.lucene.analysis.KeywordAnalyzer, hasfeaturecat=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, keyword=org.apache.lucene.analysis.KeywordAnalyzer, _cat=org.apache.lucene.analysis.KeywordAnalyzer, operatesOnIdentifier=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, operatesOn=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, _uuid=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, inspirerelated=org.apache.lucene.analysis.KeywordAnalyzer}
* Field search analyzers: {parentUuid=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, hassource=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, hasfeaturecat=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, subject=org.apache.lucene.analysis.KeywordAnalyzer, _groupPublished=org.apache.lucene.analysis.KeywordAnalyzer, keyword=org.apache.lucene.analysis.KeywordAnalyzer, _cat=org.apache.lucene.analysis.KeywordAnalyzer, operatesOnIdentifier=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, operatesOn=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, _uuid=org.fao.geonet.kernel.search.GeoNetworkAnalyzer, inspirerelated=org.apache.lucene.analysis.KeywordAnalyzer}
* Field boost factor: {_op2=0.0, _owner=0.0, _isTemplate=0.0, _op0=0.0, _op1=0.0, _dummy=0.0}
* Boost document class: null
* Tokenized fields: [abstract, keywordType, title, subject, any, levelName, altTitle, specificationTitle]
* Numeric fields: [eastBL, southBL, northBL, westBL, denominator]
* Dump fields: {_valid_schematron-rules-inspire=valid_schematron-rules-inspire, _popularity=popularity, _dynamic=dynamic, _source=source, _owner=owner, accessConstr=Constraints, link=link, _ownername=ownername, _view=view, responsibleParty=responsibleParty, type=type, _userinfo=userinfo, _locale=_locale, _valid_schematron-rules-iso=valid_schematron-rules-iso, _selected=selected, _isTemplate=isTemplate, _isPublishedToAll=isPublishedToAll, _valid=valid, classif=SecurityConstraints, _rating=rating, _cat=category, otherConstr=Constraints, _title=title, abstract=abstract, _featured=featured, _valid_schematron-rules-geonetwork=valid_schematron-rules-geonetwork, parentUuid=parentId, keyword=keyword, image=image, datasetLang=datasetLang, conditionApplyingToAccessAndUse=Constraints, _displayOrder=displayOrder, serviceType=serviceType, geoBox=geoBox, _isHarvested=isHarvested, spatialRepresentationType=spatialRepresentationType, _download=download, _valid_xsd=valid_xsd, language=language, _defaultTitle=defaultTitle, _edit=edit, _docLocale=docLocale, _notify=notify}
* Search boost query: null
* Score:
* trackDocScores: false
* trackMaxScore: false
* docsScoredInOrder: false
2013-07-30 16:35:18,295 INFO [jeeves.apphand] - Using shapefile C:\Program Files (x86)\geonetwork\web\geonetwork\WEB-INF\data\index\spatialindex.shp
2013-07-30 16:35:20,354 INFO [jeeves.apphand] - NOTE: Using shapefile for spatial index, this can be slow for larger catalogs 2013-07-30 16:35:21,431 WARN [geonetwork.lucene] - Stopwords file with incorrect ISO 639-2 language as filename: README
2013-07-30 16:35:22,492 INFO [jeeves.apphand] - - Access manager...
2013-07-30 16:35:22,492 INFO [jeeves.apphand] - - Xml serializer and Data manager...
2013-07-30 16:35:26,626 INFO [jeeves.apphand] - - Thesaurus...
2013-07-30 16:35:26,641 INFO [jeeves.apphand] - - Harvest manager...
2013-07-30 16:35:26,672 INFO [jeeves.apphand] - - Catalogue services for the web...
2013-07-30 16:35:26,704 INFO [jeeves.apphand] - - Open Archive Initiative (OAI-PMH) server...
2013-07-30 16:35:26,735 INFO [jeeves.apphand] - - Metadata notifier ...
2013-07-30 16:35:26,735 INFO [jeeves.apphand] - Site ID is : a0407672-4549-4c34-9c38-c61175a3552f
2013-07-30 16:35:27,955 INFO [jeeves.apphand] - Stopping geonetwork...
2013-07-30 16:35:27,955 INFO [jeeves.apphand] - shutting down CSW HarvestResponse executionService
2013-07-30 16:35:27,955 INFO [jeeves.apphand] - - search...
2013-07-30 16:35:27,970 INFO [jeeves.apphand] - - ThreadPool ...
2013-07-30 16:35:27,970 INFO [jeeves.apphand] - - MetadataNotifier ...
2013-07-30 16:35:27,970 INFO [jeeves.apphand] - - Harvest Manager...
2013-07-30 16:35:28,080 INFO [jeeves.apphand] - - Z39.50...
