Hi
The script you indicate it's for development only, to create new releases.
To upgrade the database from old version to newer version, if you setup the
new version of GeoNetwork to point to the database and startup GeoNetwork,
it should be updated automatically.
But it's true that the upgrade process specially if upgrading from old
versions is not as reliable as should be. If there's any error upgrading
the database should appear in the log file, please post it here to check
the error(s) reported.
Jose García
On Wed, Jan 30, 2019 at 5:03 PM Nicolas De Ville de Goyet <
ndeville@anonymised.com> wrote:
Hello again,
I'm sure I'm not the first one to struggle to update Geonetwork
I see in the source code of the geonetwork 3.4 there are shell scripts
call update-version but those script disappear when the program is
compiled...
My version on the prod server is 3.0.3 and I would like to go to 3.4.4.
I'm not an IT specialist (although learning a lot trying to upgrade
geonetwork and compiling a new version with ISO19115-3 plugin) so a few
hints would be much appreciated!
Have a nice day,
Nicolas
On 28/01/19 10:12, Ndeville wrote:
> Hello everyone,
> I'm trying to upgrade the version of geonetwork we use from 3.0.3 to
3.4.4
> to benefit from all the improvement that have been added.
> However I'm struggling to upgrade while keeping all the metadata records,
> the users accounts and the database.
> For the metadata records, I tried to copy/paste the /data folder in
WEF-INF,
> but I loose the users account and part of the metadata files (the ones
that
> are not harvested from somewhere else).
> For the database I made a copy of the one I used (h2 database) and I
tried
> to change the database link in jdbc.properties of the newly installed
> version but I get errors messages too.
> Is there somewhere a guide that summarize the steps to follow? The
manual on
> the geonetwork website is unfortunately not really helpful at the moment.
https://geonetwork-opensource.org/manuals/3.4.x/is/maintainer-guide/updating/manual-update.html
> Thanks for your help,
> Nicolas
> Sent from:
http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at
Nicolas de Ville
Belgian Marine Data Centre (BMDC)
OD-Nature, Royal Belgian Institute of Natural Sciences
02/627.42.79
www.bmdc.be
geonetwork.bmdc.be
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
