[GeoNetwork-users] GeoNetwork v2.4.3.0: xsd schema Invalid
Hi.
I am assessing xsd validation in GeoNetwork v2.4.3.0 iso19139 xsd schema and
I have discovered a number of schema files are returning invalid via an
Altova XMLSpy validation when I load the schema.xsd file for validation.
The offending files are as follows.
- datums.xsd
- dictionary.xsd
I have tried the following with the schema files.
- Sourced the original schema documents from ISO - no change to result.
- Checked the original xsd schema files from the GeoNetwork installation -
The reason I am posting this question to the GeoNetwork Community is because
we are undertaking an xml transformation from a previous template to our
latest template and with these files invalid an automated tool to undertake
this transformation is rendered "not applicable".
Is there any settings in Altova XMLSpy which will render the default schema
valid?
Thanks and kind regards, Trevor
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoNetwork-v2-4-3-0-xsd-schema-Invalid-tp5013289.html
