[GeoNetwork-users] GeoNetwork v2.4.3: Interactive Map troubleshooting
Dear GeoNetwork Users.
I am trying to get the following 'Interactive Map' functionality to work?
1. Interactive Map button associated with a metadata record?
a. I have created a test WMS GetCapabilities with the following
b. Online resource
                                                               i. URL ie. http://geos.marine.ie/ArcGIS/services/IREHABInshoreShellfishStatus/MapServer/WMSServer?request=GetCapabilities&service=WMS
                                                             ii. Protocol ie. OGC Web Map Service
                                                            iii. Name ie. IREHABInshoreShellfishStatus
                                                           iv. Description ie. Test
                                                             v. Function ie. Information
c. PRIVILEGES for the metadata record include 'Interactive map'
However, the feature does not appear?
Any help please?
Thanks and kind regards.
trv
______________________________
Trevor Alcorn
GIS Analyst
Marine Institute, Rinville, Oranmore, Co. Galway, Ireland
Email: trevor.alcorn@anonymised.com
Ph: +353 91 387476
Fax: +353 91 387201
Online Services
(Data Discovery) Irish Spatial Data Exchange: http://www.isde.ie
(Data Discovery) Marine Data Online 2.0: http://catalog.marine.ie
(Data Request) Service: www.marine.ie/home/publicationsdata/<http://www.marine.ie/home/publicationsdata/&gt;
(Data Services) Standard Map Viewer: http://www.maps.marine.ie
This message contains confidential information and is intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission.
Is don t? at? ainmithe an teachtaireacht seo agus inte t? eolas r?nda. Muna t? an t? at? ainmithe n?or ch?ir duit an r?omhphost seo a eis-sheacada, scaipeadh n? a choip?il. M? fuir t? an r?omhphost seo tr? thimpist cur a t? a sheol ? ar an eolas l?thaireach tr? r?omhphost agus scrios ? ? do choras f?in. N? f?idir a ch?nti? go bhfuil r?omhphost gan lucht n? s?bhailte de bharr m?dh seachadadh na r?omhphost. D'fh?adfach s? go nd?anfa? tascradh ar an eolas, go mbeadh s? curtha as rocht, go gcailf? n? go scriosf? ?, go mbeadh moill ar, ? easnamhach n? go mbeadh v?reas curtha leis le linn a sheachadadh. D? bhr? sin n? glacann an t? a sheol le aon mhil?an maidir le easnaimh n? but?in in ?bhar na teachtaireachta a tharla?onn le linn a sheachadadh.
I am also having the same issue. Have you been able to resolve the problem?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GeoNetwork-v2-4-3-Interactive-Map-troubleshooting-tp6626514p6665698.html
