[GeoNetwork-users] GeoNetwork v3 or v2?
Hello Internet,
I recently tested both versions from GeoNetwork and now I am puzzled which
one to use:
v3:
   - Looks better
   - Integration with GeoServer is better
      - uploading a zip file and being able to publish it
      - have all OGR Services at hand in the mapviewer,
   - Bugs
      - map view is not properly aligned after accepting cookies
      - URL NOT FOUND for TILE error if i want to add a WMS
      - Welcome Screen is different for english and german
Therefore I would like to know, if these bugs are present in the current
stable or if I am just not configuring it properly?
I will recommand you to use the GeoNetwork 3 version, obviously.
The bugs you pointed on are quite minor, most of them should have already
been fixed in current development branch.
We're planning a minor release very soon, i suggest you to try this out, or
check the 3.0.x branch to see if they are fixed in your case.
It's true that the themes are different depending on the language, they are
generated through the facets on index key 'keyword'. Meybe check that your
keywords are well translated, or maybe play with the langage settings in
the admin console.
On Thu, Jun 25, 2015 at 9:51 AM, Florian Hoedt <gannebamm@anonymised.com> wrote:
Hello Internet,
one to use:
v3:
   - Looks better
   - Bugs
Monitor 25 network devices or servers for free with OpManager!
OpManager is web-based network management software that monitors
network devices and physical & virtual servers, alerts via email & sms
for fault. Monitor 25 devices for free with no restriction. Download now
Download ManageEngine OpManager for Windows/Linux | 64 bit
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
