[GeoNetwork-users] Geonetwork Versioning (default on)
Is there a setting in Geonetwork 2.10 to set metadata versioning
(subversion) always on (without recompiling the source). The documentation
says that it is always off until each record is turned on (so it does not
look like it is possible). I just wanted to ask in case I was missing
something.
Thank you
Ian
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geonetwork-Versioning-default-on-tp5068293.html
Ian,
2013/7/23 ianwallen <ianwallen@anonymised.com>:
something.
I don't think there is option for that but it could be useful.
Francois
Thank you
Ian
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
