Hello, I recently installed the Geonetwork 2.8.0 on Tomcat 7 with database
connection Postgresql-PostGIS. But two problems happen. The homepage
Geonetwork is very slow, and when trying to Haversting Geoserver with the
error "Failed to compile stylesheet!" occurs. Please can anyone help?
Davi de O. Custódio
Hi Davi
Related to slow access, have you check the JVM memory settings? Tomcat by
default defines a very low JVM memory settings and really need to be
increased.
Related to harvester, it's related to this issue:
http://trac.osgeo.org/geonetwork/ticket/1233 We should plan for 2.8.1 soon
as this issue is preventing to work properly the OGC harvester.
If you want to apply directly in your 2.8.0 installation instead of waiting
to 2.8.1, here is the link to the related commit:
https://github.com/geonetwork/core-geonetwork/commit/3fa78361173486c0352589cf30267bf8d028776b
Jose García
On Fri, Mar 15, 2013 at 6:00 PM, Davi Custodio <davicustodio@anonymised.com>wrote:
Davi de O. Custódio
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_mar
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Garcia, thanks for the help. As for the problem with the Harvesting, I'll
try to apply the patch. But in relation to the problem of slow on the main
Geonetwork: I'm using Tomcat is running in production instances of
Geoserver and was fully optimized with respect to memory allocation. I'm
sure the problem is not related to slow it. My Tomcat is running on port
8181. Already in "System Configuration" and changed the port 8080 to 8181.
Also edited the config-file gui.xml, altered layers pointing to my
geoserver layers real, and nothing. The problem of slowness continues. The
interesting thing is that when accessing the main page of Geoserver, all my
browser (chrome) hangs until it passes about 30 seconds. The slowness
happens only on the main page. On other pages, everything happens normally.
thank you
On Fri, Mar 15, 2013 at 2:20 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Davi
increased.
soon as this issue is preventing to work properly the OGC harvester.
waiting to 2.8.1, here is the link to the related commit:
Jose García
Davi de O. Custódio
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Davi de O. Custódio
