I have deploy a Geonetwork in a Ubuntu Server 12.04 using the war
file. I wish i could use it in conjunction with Geoserver. For a
unknow reason every time i deploy a Geoserver in the webapps folder in
TomCat both programs stop working. I guess is just a matter of
setting up TomCat. In such case, is there any info available where i
could find a good way to make both works in synchro? Any clue?
As it is said in the Geonetwork web, Geoserver is integrated in the
same package, but i can't see it any folder. Which GeonetWork version
should i download to get both? Is there an easy way to upload
GeoServer without broken the server?
I used it to setup geonetwork with geoserver on Ubuntu 12.04 and it works
fine.
Stefan
2013/2/5 Jesús <gesusjl@anonymised.com>
Hi everybody.
fine.
Stefan
Hi everybody.
hi, do i have to compile GeoNetWork with maven or maven2. Also i´ve
following the instruction from http://trac.osgeo.org/geonetwork/wiki/HowToRunUnderTomcat but without
success.As it is said in the maven web page, the instruction mvn
assembly:assembly is deprecated. At this step i´ve been having too
many errors to put them all right here...
Is there an updated way to install geonetwork with geoserver in an
ubuntu 12.04 server. Thanks !
2013/2/4 Jesús <gesusjl@anonymised.com>:
Thank you Stefan.
I´ll take a look right now!.
Jesus
2013/2/4, Stefan Sylla <stefansylla@anonymised.com>:
Hi Jesus,
there is a very good instruction to configure geonetwork under tomcat,
including geoserver setup:
fine.
Stefan
Hi everybody.
