Hello,
I've researched and read various methods and documents to configure
GeoNetwork with a PostGIS database, but I still routinely get the following
error on startup:
HTTP Status 404 - /geonetwork
type Status report
message /geonetwork
description The requested resource is not available.
I've modified the following files to use my database:
/opt/tomcat/apache-tomcat-8.5.5/webapps/geonetwork/WEB-INF/jetty-env.xml
--code snippet--
<Arg>jdbc/geonetwork</Arg>
<Arg>
<New class="org.apache.commons.dbcp.BasicDataSource">
<Set name="driverClassName">org.postgis.DriverWrapper</Set>
<Set name="url">jdbc:postgresql_postGIS://localhost:5432/my_db</Set>
<Set name="username">myusername</Set>
<Set name="password">mypassword</Set>
<Set name="validationQuery">SELECT 1</Set>
<Set name="maxActive">10</Set>
<Set name="maxIdle">10</Set>
<Set name="removeAbandoned">true</Set>
<Set name="removeAbandonedTimeout">3600</Set>
<Set name="logAbandoned">true</Set>
<Set name="testOnBorrow">true</Set>
<Set name="defaultAutoCommit">false</Set>
<Set name="defaultTransactionIsolation">2</Set>
<Set name="accessToUnderlyingConnectionAllowed">true</Set>
</New>
</Arg>
/opt/tomcat/apache-tomcat-8.5.5/webapps/geonetwork/WEB-INF/config-db/jdbc.properties
--code snippet--
jdbc.username=myusername
jdbc.password=mypassword
jdbc.database=my_db
jdbc.host=localhost
jdbc.port=5432
jdbc.basic.removeAbandoned=true
jdbc.basic.removeAbandonedTimeout=120
jdbc.basic.logAbandoned=true
jdbc.basic.maxActive=33
jdbc.basic.maxIdle=${jdbc.basic.maxActive}
jdbc.basic.initialSize=${jdbc.basic.maxActive}
jdbc.basic.maxWait=200
jdbc.basic.testOnBorrow=true
jdbc.basic.timeBetweenEvictionRunsMillis=10000
jdbc.basic.minEvictableIdleTimeMillis=1800000
jdbc.basic.testWhileIdle=true
jdbc.basic.numTestsPerEvictionRun=3
jdbc.basic.poolPreparedStatements=true
jdbc.basic.maxOpenPreparedStatements=1200
jdbc.basic.validationQuery=SELECT 1
jdbc.basic.defaultReadOnly=false
jdbc.basic.defaultAutoCommit=false
/opt/tomcat/apache-tomcat-8.5.5/webapps/geonetwork/WEB-INF/config-node/srv.xml
--code snippet--
<import resource="../config-db/postgres-postgis.xml"/>
Even if I revert back to the original versions of these files and restart
the server, I still receive the 404 error.
Can anybody shed some light on this?
Maybe additional configuration is needed on the PostGIS database side to
allow for PostGIS connection?
Thanks, Kevin
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-with-PostGIS-configuration-problem-tp5311204.html
