Hi Greg,
Sorry for the delay in getting back to you with our geonetwork WAF script-
I had to edit our existing one quite a bit to remove the additional
features. You can find it at
https://github.com/AstunTechnology/geonetwork_waf_processing. Note that
it's not really a "supported product" from Astun, just a little script that
we use, but if you find any issues please let us know via github. Note also
that it's only tested with Geonetwork 2.10 and the Gemini 2.2 schema, so
you will definitely need to change it to work for your requirements, but I
hope it's useful.
Regards
Jo
On Thu, Jan 29, 2015 at 9:52 AM, Greg Byrom <greg.byrom@anonymised.com>
wrote:
Thanks Jo, yes please! That would be great if you could. I can't see
why geonetwork doesn't have this functionality built in. Maybe I should
post to the developer list and see if anyone decides to take it up...
But on thee anyone that would be awesome if you could. Thanks!
Greg.
Sent from my iPhone
On 29/01/2015, at 22:47, Jo Cook <jocook@anonymised.com> wrote:
Hi Greg,
We encountered a similar problem and ended up writing a python script to
iterate through the folders, figure out the title for each record, and
rename the file accordingly. Our script also does a bunch of other things
too, but if you don't get a better solution I'd be willing to pop it on
github so you can edit it to suit your needs.
Regards
Jo
On Wed, Jan 28, 2015 at 9:59 PM, Greg Byrom <greg.byrom@anonymised.com>
wrote:
Hi list
The standard Geonetwork MEF and TXT format exports are not suitable for
my purposes. How is it possible to export BULK metadata records from
geonetwork with individual XML files named the same as the Title or
Alternate Title of the dataset being described?
This seems like it should be easy but I can see no way to do so. Is there
a style sheet which will help?
Many thanks
Greg.
GREG BYROM
SENIOR CONSULTANT
DDI: +64 4 910 6230 | M: +64 21 828 446 | E: greg.byrom@anonymised.com
<mailto:greg.byrom@anonymised.com>
CRITCHLOW LIMITED | KNOW WHERE
Level 2, 22 The Terrace, PO Box 4103, Wellington 6140, New Zealand
P: +64 4 472 8244 * NZ Toll-free 0800 627 746 * F: +64 4 472 6695
www.critchlow.co.nz<
http://t.signauxtrois.com/e1t/c/5/f18dQhb0S7lC8dDMPbW2n0x6l2B9nMJW7t5XZs2BFKzvVdVgnT8r4N8lW2zq5cM56dS8Hf5xdn2402?t=http%3A%2F%2Fwww.critchlow.co.nz%2F&si=&pi=525b23573fd541f891ae32ecf40ca4b8>
@CritchlowNZ<
http://t.signauxtrois.com/e1t/c/5/f18dQhb0S7lC8dDMPbW2n0x6l2B9nMJW7t5XZs2BFKzvVdVgnT8r4N8lW2zq5cM56dS8Hf5xdn2402?t=http%3A%2F%2Fwww.twitter.com%2FCritchlowNZ&si=&pi=525b23573fd541f891ae32ecf40ca4b8
[MapInfo Pro webinar nov 2014 (1)]<
http://t.signauxtrois.com/e1t/c/5/f18dQhb0S7lC8dDMPbW2n0x6l2B9nMJW7t5XZs2BFKzvVdVgnT8r4N8lW2zq5cM56dS8Hf5xdn2402?t=http%3A%2F%2Fhubs.ly%2Fy0g2GR0&si=5234401107509248&pi=5806260ae16c4593bba321f74fd5750d
This email transmission (including any accompanying attachments) contains
confidential information, which may be subject to legal privilege intended
for the named addressee.
If any other reader is not the intended recipient, you are hereby
notified that any use, dissemination, distribution or reproduction of this
email is prohibited. If you have received this
email in error please contact us immediately.
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is
your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
GeoNetwork-users mailing list
*Jo Cook*
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
t:+44 7930 524 155
iShare - Data integration and publishing platform
<http://www.isharemaps.com/>
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
*Jo Cook*
7RL, UK
t:+44 7930 524 155
864201149.
