[GeoNetwork-users] Geoportal issues
Hi Marten,
With respect to the ANZLIC (& MCP) profiles of the ISO spec, the OGC ANZ forum met on 8th Nov, where a resolution was passed:
"The Forum discussed the imminent publication of ISO19115-1 (2014), and
passed a motion to urge ANZLIC to adopt the 'root' international profile for ANZ purposes, rather
than create its own."
So hopefully we are on convergent paths, at least as far as ISO compliant profiles go. One issue at a time :slight_smile:
Brent Wood
To: Lionel Menard <lionel.menard@anonymised.com>; "geonetwork-users@anonymised.comeforge.net" <geonetwork-users@lists.sourceforge.net>
Cc: "simon.pigot@anonymised.com" <simon.pigot@anonymised.com>
Sent: Tuesday, November 26, 2013 11:58 AM
Subject: Re: [GeoNetwork-users] Geoportal issues
Our sandbox
site at http://gptogc.esri.com regularly harvests from a variety of catalogs including several GeoNetwork implementations. Here is a list: http://gptogc.esri.com/geoportal/rest/repositories
One of these is the web services energy site:
http://geocatalog.webservice-energy.org/geonetwork/srv/eng/csw?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetCapabilities
Out of the 907 records the last harvest validated and published 777. This illustrates one possible challenge: different catalogs may implement different validation rules for metadata.
Another issue I have seen many times is in the registration itself where we require the
CSW to have a title in the capabilities statement. Many GeoNetwork CSW don't have this and without that you won't get through the registration process. This even holds for significant CSW like the GEOSS clearinghouse:
http://ec2-50-19-223-225.compute-1.amazonaws.com/geonetwork/srv/en/csw?request=GetCapabilities&service=CSW&version=2.0.2
what I then do is rehost the capabilities file as a straight XML file and register that with geoportal as a proxy for the actual CSW. The above is available here:
https://dl.dropboxusercontent.com/u/14831068/cswproxy/geoss_clearinghouse.xml
Furthermore: different CSW respond differently. For example the NIWA (New
Zealand) catalog responds with ISO metadata in a different namespace
http://dc.niwa.co.nz/niwa_dc/srv/eng/main.home
http://dc.niwa.co.nz/niwa_dc/srv/eng/csw?service=CSW&request=GetRecordById&version=2.0.2&ElementSetName=full&OutputSchema=csw:IsoRecord&ID=c583f085-f2aa-42fd-a1ac-076703d09dde
mcp:MD_Metadata xmlns:mcp="http://bluenet3.antcrc.utas.edu.au/mcp&quot;
that means we have to update our profiles of GeoNetwork CSW interaction when we see these things.
[cid:image001.jpg@anonymised.com]
-----Original Message-----
From: Lionel Menard [mailto:lionel.menard@anonymised.com]
Sent: Monday, November 25, 2013 10:17 AM
To: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@anonymised.comurceforge.net>
Hi everyone,
thanks Jacqueline for your testimony. Unfortunately implementing is one thing and harvesting between implementations is an other thing...Have you had any successful harvest from GeoNetwork
to Geoportal you could report ?
@Simon: I tested the Geoportal Harvester with the help of the link you provide. The target version is:
ArcGIS Server Geoportal Extension 10 - OGC CSW 2.0.2 ISO AP Unfortunately this still does not work.
I set one keyword for Search Criteria: (solar) I tested with both XSTL options set to: Add-gmd-prefix and gmiTogmd. Same results.
From the "History" link in the "Harvest Manager" section I get the
following
message: "Harvested Nothing".
I also get this message in the log:
2013-11-25 18:36:34,862 WARN [geonetwork.harvester] - Skipped record not in supported format
I also did the test with the example Geoportal of the doc you provide:
http://www.ngdc.noaa.gov/geoportal
Same behavior...
Any thoughts about what's going wrong
Lionel
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoportal-issues-tp5047261p5091082.html
Shape the Mobile Experience: Free Subscription Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
Free Subscription
