Hi
I am trying to harvest a geoportal REST/csw that is on the same virtual server as Geonetwork 3.0.2. Neither the CSW or geoportalREST is working.
For CSW I used this address: http://server:8080/geoportal/csw
For REST I used: http://server:8080/geoportal
I also applied to 'add-gmd-prefix' to the XSL transformation and tested on/off remote authentication.
I have tested accessing the CSW in QGIS and it works fine.
I get the following log error when I run the harvest:
{"error": { "message": "opendap.servlet.BadURLException: This doesn't seem like a harvester log file. Stopping possible hacking attempt to uri: logs\harvester_geoPREST_WaterNSW_GeoportalREST_201512091557.log" , "class": "RuntimeException" , "stack": { "at": "jeeves.transaction.TransactionManager TransactionManager.java line 98 #runInTransaction" , "at": "jeeves.server.dispatchers.ServiceInfo ServiceInfo.java line 114 #execServices" , "at": "jeeves.server.dispatchers.ServiceManager ServiceManager.java line 442 #dispatch" , "at": "jeeves.server.dispatchers.ServiceManager ServiceManager.java line 384 #dispatch" , "at": "jeeves.server.JeevesEngine JeevesEngine.java line 600 #dispatch" , "at": "org.fao.geonet.services.main.GenericController GenericController.java line 106 #dispatch" , "at": "sun.reflect.GeneratedMethodAccessor279 ??? line -1 #invoke" , "at": "sun.reflect.DelegatingMethodAccessorImpl ??? line -1 #invoke" , "at": "java.lang.reflect.Method ??? line -1 #invoke" , "at": "org.springframework.web.method.support.InvocableHandlerMethod InvocableHandlerMethod.java line 219 #invoke" , "at": "jeeves.config.springutil.JeevesDispatcherServlet JeevesDispatcherServlet.java line 17 #access$001" , "at": "jeeves.config.springutil.JeevesDispatcherServlet$1 JeevesDispatcherServlet.java line 30 #doInTransaction" , "at": "jeeves.config.springutil.JeevesDispatcherServlet$1 JeevesDispatcherServlet.java line 27 #doInTransaction" , "at": "jeeves.transaction.TransactionManager TransactionManager.java line 63 #runInTransaction" , "at": "jeeves.config.springutil.JeevesDispatcherServlet JeevesDispatcherServlet.java line 24 #doDispatch" , "at": "org.fao.geonet.monitor.webapp.WebappMetricsFilter WebappMetricsFilter.java line 96 #doFilter" , "at": "org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter MetricsRegistryInitializerFilter.java line 31 #doFilter" , "at": "org.geonetwork.http.SessionTimeoutCookieFilter SessionTimeoutCookieFilter.java line 56 #doFilter" , "at": "jeeves.config.springutil.PassthroughFilter PassthroughFilter.java line 26 #doFilter" , "at": "jeeves.config.springutil.MultiNodeAuthenticationFilter MultiNodeAuthenticationFilter.java line 98 #doFilter" , "at": "jeeves.config.springutil.JeevesDelegatingFilterProxy JeevesDelegatingFilterProxy.java line 64 #doFilter" } , "request": {} } }
Regards
Mark Noonan
Spatial Services Manager
[http://www.impressdesign.com.au/images/water_nsw_logo.png\]
Level 4, 2-6 Station Street. Penrith NSW 2751
T: 02 47242310 M: 0408169624
mark.noonan@anonymised.com<mailto:mark.noonan@anonymised.com>
www.waternsw.com.au<http://www.waternsw.com.au/>
Spatial Science
Email - gis@anonymised.com<mailto:gis@anonymised.com>
[cid:image002.png@anonymised.com]<http://vmags/>
(attachments)
