Hi Bart,
attached you find the documentation of the google maps integration that I did. It also includes a list of files that needed to be changed and what has been changed there.
Max
Von: Ooms Bart [mailto:bart.ooms@anonymised.com]
Gesendet: Donnerstag, 13. Juni 2013 16:36
An: Max Stephan; geonetwork-users@lists.sourceforge.net
Betreff: RE: [GeoNetwork-users] GeoNetwork/Google Maps integration
Hello Max,
Do you have a list of all files you have updated for the EPSG900913 integration?
Bart
-----Original Message-----
From: Max Stephan [mailto:max.stephan@anonymised.com]
Sent: woensdag 12 juni 2013 16:22
To: Ooms Bart; geonetwork-users@lists.sourceforge.net
Subject: AW: [GeoNetwork-users] GeoNetwork/Google Maps integration
That´s strange. Do you have a link on the web so that I could check it? Have you changed the Coordinate System for the map everywhere to EPSG:900913 (also in the config-gui.xml). Usually when adding an overlay to the OpenLayers-Map it performs the request in the Coordinate Reference System of the basemap (and also with the coordinates of the basemap).
Max
Gesendet: Mittwoch, 12. Juni 2013 15:33
Max,
I can see the google map now but I still have a problem when putting extra layers on it. The WMS call when clicking a interactive map button has the wrong coordinates(still WGS84). Do you have any idea which script I have to change, because I don't see where the WMS coordinates are calculated.
Best regards,
Bart
Sent: dinsdag 11 juni 2013 15:38
Dear Bart,
yep, bounding-box in the metadata should be still in WGS-84. We changed the baselayer of the of the map which displays the map-extent to a WGS84 so that we could still keep the WGS84 coordinates in the metadata-sets.
If you left the config-gui.xml unaltered and change the google-layer for ol_map and ol_minimap directly in the scripts, this should be the case automatically and in the metadata-map you should still see the backgroundlayer as defined in config-gui.xml. If you defined the google-layer in config-gui.xml though, you have to perform changes in extentmap.js, so that you override the backgroundlayers from config-gui.xml.
Max
Gesendet: Dienstag, 11. Juni 2013 15:00
Hey Max,
So the coordinates of the bounding box in the metadata should be in WGS84 because the search function will take those fields to do the geographical search? Am I correct?
These boundingbox fields are also visualized in a map when you open the metadata in detail. The background layer is also the google map with its own CRS. The bounding box is in WGS84 so there will be a fault when the wgs84 coordinates are mapped on the google map.
I'm using geonetwork2.6.4
Bart
Sent: dinsdag 11 juni 2013 14:23
Hey Bart,
no, you don´t have to change the bounding-box coordinates. They can remain in WGS84 (we did it like that as well). Coordinates which come from the search-map when you perform a geographical search are automatically transformed to WGS84 as far as I remember (it´s been some time since I made these changes).
What you could look into as well is performing a switch to the widget-interface (as far as I understand this is also the path for the future, the old traditional UI will be replaced by the new, widget-based UI). In the Widget-UI it is MUCH simpler to switch the coordinate reference system and base map to google maps or OpenStreetMap (just a matter of commenting out a few lines and uncommenting a few other lines in the settings.js for the map).
Best regards
Max
Gesendet: Dienstag, 11. Juni 2013 13:40
Max,
When changing the background to google maps we have to set the CRS to EPSG:900913 or 3857 in geonetwork.
Does it mean that all the Geographic bounding boxes of all the metadata needs to be defined in above EPSG code?
All metadata that is currently in geonetwork uses WSG84 in its geographic bounding box tag. I guess we have to adapt all bounding boxes of all records to use the google EPSG code?
Bart
Sent: vrijdag 31 mei 2013 22:12
To: Aklilu Dinkneh; geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] GeoNetwork/Google Maps integration
Dear Akilu,
congrats. I actually don´t know why this error occurs now. Shouldn´t have anything to do with your changes. Have you checked if the respective javascript es.js exists? The error didn´t occur before you applied the changes I suppose?
Good luck
Max
P.S.: Please send your mails/replies always to geonetwork-user@anonymised.comforge.net<mailto:geonetwork-user@lists.sourceforge.net> as well so that other users can also access and gain their knowledge from them.
Von: Aklilu Dinkneh [mailto:akliludin@anonymised.com]
Gesendet: Donnerstag, 30. Mai 2013 19:18
An: Max Stephan
Betreff: Re: [GeoNetwork-users] GeoNetwork/Google Maps integration
Dear Max,
Me again I think I made a good progress after going through the material you suggested and now I have only one error which i couldnt figure out.
I attached here the screen shot do you have any idea what my problem is? Thank you very much for your time with best regards
On Thu, May 30, 2013 at 7:16 PM, Aklilu Dinkneh <akliludin@anonymised.com<mailto:akliludin@anonymised.com>> wrote:
Dear Max,
I attached here the screen shot do you have any idea what my problem is? Thank you very much for your time with best regards Aklilu
On Sat, May 25, 2013 at 2:54 PM, Max Stephan <max.stephan@anonymised.com<mailto:max.stephan@anonymised.com>> wrote:
Hi Akilu,
please make sure that you imported the google-maps-API in main-page.xsl like this:
<script src="http://maps.google.com/maps/api/js?v=3&sensor=false"></script>
Instead of following the more complicated instructions I provided in this thread earlier, I would recommend you to first add a google-layer manually to the map. This openLayers-example gives you an idea how to do that: http://openlayers.org/dev/examples/all-overlays-google.html . If you get this to work you might then proceed with integrating the configuration in config-gui.xml etc.
Max
Gesendet: Samstag, 25. Mai 2013 14:46
An: Max Stephan
Hi Max,
Thanks a lot for your fast reply I have followed your explanation to different people and followed the steps you explained and I got some error which I attached here do you think you can explain me what I miss?
best regards
Aklilu
[cid:image001.png@anonymised.com]
On Sat, May 25, 2013 at 2:23 PM, Max Stephan <max.stephan@anonymised.com<mailto:max.stephan@anonymised.com>> wrote:
Hey Akilo,
adding a google-maps-layer to the search-map requires you to edit the script "ol_minimap.js". This script is responsible for creating the OpenLayers-based map-object and adds the WMS-layers defined in config-gui.xml to this map. Instead of the WMS-layers you need to create a google-layer in this script and then add it to the map. For this to work, you also have to import the google-maps-API in main-page.xsl. Lastly you will have to minify the scripts, so that it´s not only working in the debug-version. It´s not a simple task if you´re not familiar with editing geonetwork or coding.
Have a look at our geonetwork´s ol_minimap.js-script to get an idea how it should look like: http://131.220.109.2/geonetwork/scripts/ol_minimap.js (though this version differs because we adapted our geonetwork so that google-layers can also be configured through config-gui.xml).
I hope this can give you a rough idea of what you need to change.
Max
Von: aklilu [mailto:akliludin@anonymised.com]
Gesendet: Samstag, 25. Mai 2013 13:32
An: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@anonymised.comurceforge.net>
Betreff: [GeoNetwork-users] GeoNetwork/Google Maps integration
Dear Geonetwork users
I have tried to go through all past posts regarding integration of googel into Geonetwork(small search map) but I couldnt find a clear answer how to do this so I am here asking for help. could some one please help me in clarifing what I have to do or linking me to a document which describe how to do this.
thank you for your help
best regards,
Aklilu
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Google-Maps-integration-tp3860447p5055709.html
Try New Relic Now & We'll Send You this Cool Shirt New Relic is the only SaaS-based application performance monitoring service that delivers powerful full stack analytics. Optimize and monitor your browser, app, & servers with just a few lines of code. Try New Relic and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_may
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
[http://www.vito.be/e-maildisclaimer/vito.png\]
Ontdek hoe VITO de transitie naar een duurzame maatschappij op gang trekt: www.vito.be/duurzaamheidsverslag2012<http://www.vito.be/duurzaamheidsverslag2012>
Discover how VITO initiates the transition towards a sustainable society: www.vito.be/sustainabilityreport2012<http://www.vito.be/sustainabilityreport2012>
VITO Disclaimer: http://www.vito.be/e-maildisclaimer
(attachments)
Google maps integration.odt (9.8 KB)
