Hi Sarah
Check if JAI 1.1.X (http://java.sun.com/products/java-media/jai/current.html) is installed in your JDK, I saw in some posts that seems that the problem you have can be caused because having an old version of JAI or not having it installed.
Make sure you install the lastest versions of both Java Advanced Imaging-Image I/O Tools and Java Advanced Imaging API for the JDK.
Jose García
----- Original Message ----- From: "Pickering, Jason Paul" <pickeringj@anonymised.com>
To: "Sarah_S" <Sarah_flip@anonymised.com>; <geonetwork-users@lists.sourceforge.net>
Sent: Tuesday, September 15, 2009 4:09 PM
Subject: Re: [GeoNetwork-users] Geoserver with Tomcat: map not shown
Hi Sarah,
If you are having issues with Geoserver, you should address it to the Geoserver mailing list, but before you do that I will ask a few questions and make a few reccomendations.
1) What did you add server.xml ?
2) What version of Java and Tomcat are you using? I would recommend to upgrade to at least Apache Tomcat 6.0.18 and Java 6. You should be sure that you install the full Java SDK, not the "normal" Java Runtime Edition.
3) I would recommend as well that you upgrade to the latest version of Geoserver, replacing the version of Geoserver that may be distributed with Geonetwork.
3) Is Geonetwork working, in spite of the messages about Geoserver?
jason
Jason P. Pickering
Consultant
WHO/Ministry of Health Zambia
email: pickeringj@anonymised.com
tel: +260968395190
-----Original Message-----
Sent: Tue 2009-09-15 15:29
To: geonetwork-users@lists.sourceforge.net
I want to run Gn on Tomcat not on Jetty.
But I don´t exactly know which changes I have to made?
I copied these folders to webapps and insert contexts at server.xml.
I found this post http://www.nabble.com/NoSuchFieldError-td19443722.html
because of my log from geoserver:
Exception sending context initialized event to listener
instance of class org.geoserver.GeoserverInitSatrtupListener
java.lang.NoSucheFieldError: KEY_REPLACE_INDEX_COLOR_MODEL.
Am I on the right way? Or is my error an servlet container problem?
Thanks.
Best regards
sarah
Pickering, Jason wrote:
Hi there.
Now I am a bit confused. Are you running both Jetty as well as Tomcat?
You should probably not run both, or if you do, you will need to change
the default port of Tomcat (or Jetty) so that they are not running on both
port 8080.
Did you copy over the /geonetwork, /geoserver/ and /intermap files to your
Tomcat /webapps directory?
Best regards,
Jason
Jason P. Pickering
Consultant
tel: +260968395190
Sent: Mon 2009-09-14 17:34
I tried re-install, but it didn´t work either. Same problems. Any ideas to
my
log-files or so on?
I looked at mapServers.xml and start-stdln.html (and mainPreviewData.html)
and tried to change port but it didn´t work.
For me it looks like that Geoserver is at Jetty while GN and Intermap are
at
Tomcat, because there are logs at jetty-folder. Or is this behaviour ok?
Any help would be appreciated!
Sarah
Sarah_S wrote:
Thank you Jason!
So here are my log from Catalina.2009-09-11:
11.09.2009 10:27:55 org.apache.tomcat.util.digester.SetPropertiesRule
begin
WARNUNG: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting
property 'debug' to '0' did not find a matching property.
begin
property 'relaodable' to 'false' did not find a matching property.
begin
begin
begin
begin
11.09.2009 10:27:55 org.apache.catalina.core.AprLifecycleListener init
INFO: Loaded APR based Apache Tomcat Native library 1.1.16.
INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters
[false], random [true].
11.09.2009 10:27:56 org.apache.coyote.http11.Http11AprProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-80
11.09.2009 10:27:56 org.apache.coyote.ajp.AjpAprProtocol init
INFO: Initializing Coyote AJP/1.3 on ajp-8009
11.09.2009 10:27:56 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 969 ms
11.09.2009 10:27:56 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
11.09.2009 10:27:56 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.20
11.09.2009 10:27:56 org.apache.catalina.ha.tcp.SimpleTcpCluster start
INFO: Cluster is about to start
11.09.2009 10:27:57 org.apache.catalina.tribes.transport.ReceiverBase
bind
INFO: Receiver Server Socket bound to:/10.33.53.59:4000
11.09.2009 10:27:57
org.apache.catalina.tribes.membership.McastServiceImpl
setupSocket
INFO: Setting cluster mcast soTimeout to 500
11.09.2009 10:27:57
waitForMembers
INFO: Sleeping for 1000 milliseconds to establish cluster membership,
start level:4
11.09.2009 10:27:58
waitForMembers
INFO: Done sleeping, membership established, start level:4
11.09.2009 10:28:00
waitForMembers
start level:8
11.09.2009 10:28:01
waitForMembers
INFO: Done sleeping, membership established, start level:8
11.09.2009 10:28:17 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/geoserver] startup failed due to previous errors
11.09.2009 10:28:26 org.wfp.vam.intermap.services.wmc.MailWmcContext init
WARNUNG: *** The mailserver config property has not been set. WMC mail
will not be available.
11.09.2009 10:28:26 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive servlet.war
INFO: Deploying web application archive wfsconnector.war
11.09.2009 10:28:26 org.apache.catalina.ha.session.DeltaManager start
INFO: Register manager /wfsconnector to cluster element Engine with name
Catalina
INFO: Starting clustering manager at /wfsconnector
getAllClusterSessions
INFO: Manager [localhost#/wfsconnector]: skipping state transfer. No
members active in cluster group.
INFO: Deploying web application archive wmsconnector.war
11.09.2009 10:28:27 org.apache.catalina.ha.session.JvmRouteBinderValve
start
INFO: JvmRouteBinderValve started
11.09.2009 10:28:27 org.apache.coyote.http11.Http11AprProtocol start
INFO: Starting Coyote HTTP/1.1 on http-80
11.09.2009 10:28:27 org.apache.coyote.ajp.AjpAprProtocol start
INFO: Starting Coyote AJP/1.3 on ajp-8009
11.09.2009 10:28:27 org.apache.catalina.startup.Catalina start
INFO: Server startup in 31071 ms
11.09.2009 10:54:11 org.geotools.factory.FactoryRegistry scanForPlugins
WARNUNG: Can't load a service for category "ConverterFactory". Cause is
"NoClassDefFoundError: org/apache/commons/beanutils/Converter".
11.09.2009 11:14:34 org.apache.coyote.http11.Http11AprProtocol pause
INFO: Pausing Coyote HTTP/1.1 on http-80
11.09.2009 11:14:34 org.apache.coyote.ajp.AjpAprProtocol pause
INFO: Pausing Coyote AJP/1.3 on ajp-8009
11.09.2009 11:14:35 org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
11.09.2009 11:14:35 org.apache.catalina.ha.session.JvmRouteBinderValve
stop
INFO: JvmRouteBinderValve stopped
11.09.2009 11:14:37 org.apache.catalina.ha.session.DeltaManager stop
INFO: Manager [localhost#/wfsconnector] expiring sessions upon shutdown
11.09.2009 11:14:37 org.apache.catalina.core.StandardContext stop
INFO: Container
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/geoserver]
has not been started
11.09.2009 11:14:48 org.apache.coyote.http11.Http11AprProtocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-80
11.09.2009 11:14:48
org.apache.catalina.tribes.membership.McastServiceImpl$ReceiverThread run
WARNUNG: Error receiving mcast package. Sleeping 500ms
java.net.SocketException: socket closed
at java.net.PlainDatagramSocketImpl.receive0(Native Method)
at java.net.PlainDatagramSocketImpl.receive(Unknown Source)
at java.net.DatagramSocket.receive(Unknown Source)
at
org.apache.catalina.tribes.membership.McastServiceImpl.receive(McastServiceImpl.java:314)
at
org.apache.catalina.tribes.membership.McastServiceImpl$ReceiverThread.run(McastServiceImpl.java:414)
11.09.2009 11:14:49 org.apache.coyote.ajp.AjpAprProtocol destroy
and this is the log from geonetwork (part of error section):
2009-09-11 10:17:07,241 INFO [jeeves.request] -
2009-09-11 10:17:07,241 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/en/main.home
2009-09-11 10:17:07,241 DEBUG [jeeves.request] - Method : GET
2009-09-11 10:17:07,241 DEBUG [jeeves.request] - Content type : null
2009-09-11 10:17:07,241 DEBUG [jeeves.request] - Accept :
image/gif,
image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash,
2009-09-11 10:17:07,241 DEBUG [jeeves.request] - Session id is
1B1F1165A16EA13F1A3232E4F48858DA
2009-09-11 10:17:07,241 INFO [jeeves.service] - Dispatching : main.home
2009-09-11 10:17:07,241 DEBUG [jeeves.service] - -> no input parameters
2009-09-11 10:17:07,241 INFO [jeeves.service] - -> dispatching to
output for : main.home
2009-09-11 10:17:07,397 INFO [jeeves.service] - -> transforming
with
stylesheet : C:\Programme\geonetwork\web\geonetwork\/xsl/main-page.xsl
2009-09-11 10:17:07,491 INFO [jeeves.service] - -> end
transformation for : main.home
2009-09-11 10:17:07,491 INFO [jeeves.service] - -> output ended for :
main.home
2009-09-11 10:17:07,491 INFO [jeeves.service] - -> dispatch ended for :
main.home
2009-09-11 10:17:09,850 INFO [jeeves.request] -
2009-09-11 10:17:09,850 INFO [jeeves.request] - HTML Request (from
127.0.0.1) : /geonetwork/srv/en/null
2009-09-11 10:17:09,850 DEBUG [jeeves.request] - Method : GET
2009-09-11 10:17:09,850 DEBUG [jeeves.request] - Content type : null
2009-09-11 10:17:09,850 DEBUG [jeeves.request] - Accept : */*
2009-09-11 10:17:09,850 DEBUG [jeeves.request] - Session id is
2009-09-11 10:17:09,850 INFO [jeeves.service] - Dispatching : null
2009-09-11 10:17:09,850 DEBUG [jeeves.service] - -> no input parameters
2009-09-11 10:17:09,850 ERROR [jeeves.service] - Service not found : null
2009-09-11 10:17:09,850 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="service-not-found">
<message>Service not found</message>
<class>ServiceNotFoundEx</class>
<stack>
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="343" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="174" method="execute" />
file="JeevesServlet.java" line="89" method="doGet" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="617" method="service" />
line="717" method="service" />
<at class="org.apache.catalina.core.ApplicationFilterChain"
file="ApplicationFilterChain.java" line="290" method="internalDoFilter"
file="ApplicationFilterChain.java" line="206" method="doFilter" />
<at class="org.apache.catalina.core.StandardWrapperValve"
file="StandardWrapperValve.java" line="233" method="invoke" />
<at class="org.apache.catalina.core.StandardContextValve"
file="StandardContextValve.java" line="191" method="invoke" />
</stack>
null
<request>
<language>en</language>
<service>null</service>
</request>
</error>
Thank you for your help!
Sarah
It would be good if you could post the log files someplace.
On Windows, they are normally located in
c:\Program Files\Apache Software Foundation\Tomcat 6.0\logs (or
something
similar).
There should be a file there called catalina.out. Open this up and see
if
you see any error messages towards the end of the file. You can post
those here and maybe we can help you further.
Best regards,
Jason
Jason P. Pickering
Consultant
tel: +260968395190
Sent: Fri 2009-09-11 08:56
Here are more detail:
Apache Tomcat/6.0.20 1.6.0_16-b01 Windows XP 5.1 x86
In my tomcat manager I could notice that geoserver is not been started.
And
there is an error if I try to start manually: Application at context
path
/geoserver could not be started.
Thank you for any help!
Sarah
Sarah_S wrote:
Hello Michael,
thank you for your help!
I´m using Windows XP Prof. Tomcat and Geonetwork are on a virtual
machine
(Port 80). Do you think I should perhaps re-install GN?
Any help would be appreciated.
Thanks
Sarah
Michael.Stegherr wrote:
Hi Sarah,
Sent: Thursday, 10 September 2009 8:05 PM
Subject: [GeoNetwork-users] Geoserver with Tomcat: map not shown
I read this:
http://trac.osgeo.org/geonetwork/wiki/HowToRunUnderTomcat and
did copy my subdirectories (point 3), changed data_dir (point
5) but don´t
know exactly how to do point 4. I don´t understand this
point. And is point
6 essential? If so where can I find the path
/etc/default/tomcatXXX (I´ve
looked at server.xml but there are no security parameter)?
Which OS are you using? I appended this info, when I experienced
difficulties in installing GeoNetwork on Tomcat running on a Linux
box.
Not sure how you can do that on Windows though. Maybe someone else can
help?
Michael
Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
trial. Simplify your report design, integration and deployment - and
focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
View this message in context:
http://n2.nabble.com/Geoserver-with-Tomcat-map-not-shown-tp3617208p3623977.html
30-Day
focus on
30-Day
focus on
http://n2.nabble.com/Geoserver-with-Tomcat-map-not-shown-tp3617208p3643259.html
30-Day
trial. Simplify your report design, integration and deployment - and focus
on
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9-12, 2009. Register
now!
http://p.sf.net/sfu/devconf
View this message in context: http://n2.nabble.com/Geoserver-with-Tomcat-map-not-shown-tp3617208p3649062.html
ahead of the curve. Join us from November 9-12, 2009. Register now!
