[GeoNetwork-users] Geoserver with Tomcat: map not shown
Hi Sarah
Check if you have these files in the subdirs of your Java install:
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
LICENSE-jai_imageio.txt
If you don't have them, install from the link I send before. In LICENSE
files you can check the versions to verify that are correct in the case you
have now installed.
Jose García
----- Original Message ----- From: "Sarah_S" <Sarah_flip@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Tuesday, September 15, 2009 4:33 PM
Subject: Re: [GeoNetwork-users] Geoserver with Tomcat: map not shown
Hi josegar,
at my webapps/geoserver/WEB_INF/lib folder there are jai_codec-1.1.3,
jai_core-1.1.3 and jai_imageio-1.1. Furthermore there are some jars at
intermap/WEB_INF/lib folder.
Where/How can I check the jai version furthermore?
And how to check I/O Tools and Advanced Imaging API for the JDK?
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
(http://java.sun.com/products/java-media/jai/current.html) is installed in
your JDK, I saw in some posts that seems that the problem you have can be
caused because having an old version of JAI or not having it installed.
Make sure you install the lastest versions of both Java Advanced
Imaging-Image I/O Tools and Java Advanced Imaging API for the JDK.
Jose García
View this message in context: http://n2.nabble.com/Geoserver-with-Tomcat-map-not-shown-tp3617208p3649402.html
Come build with us! The BlackBerry&reg; Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9&#45;12, 2009. Register now&#33;
http://p.sf.net/sfu/devconf
GeoNetwork-users mailing list
hi josegar,
the jai.dlls are here but not the I/O-Tools.
At link there are different versions to install (.zip, jre, jdk)- which one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
in
be
Jose García
stay
now&#33;
now&#33;
View this message in context: http://n2.nabble.com/Fw-Geoserver-with-Tomcat-map-not-shown-tp3649521p3649580.html
Hi there. These tools are not explicity required by Geoserver. They generally result in performance increases, but are not totally necessary. However, if you are using an older version of Geoserver, as Jose pointed out, you may run into these problems.
Again, I would reccomend to do a compltely clean install of your Java package, downloading the latest SDK from Sun to be 100% sure. Google will lead you there.
Once this is done, set a JAVA_HOME environment variable pointing to where you installed the Java SDK.
I would strongly consider installing the latest version of Geoserver (just drop the war file into the Tomcat webapps directory) once you have installed the Java SDK.
I have followed this procedure on Win 2003 and Win XP and had no problems with getting Geoserver/Geonetwork/Intermap to run properly.
Good luck.
Jason
Jason P. Pickering
Consultant
WHO/Ministry of Health Zambia
email: pickeringj@anonymised.com
tel: +260968395190
Sent: Tue 2009-09-15 17:06
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Fw: Geoserver with Tomcat: map not shown
hi josegar,
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
in
be
Jose García
stay
now&#33;
now&#33;
Hi Sarah
Normally Tomcat runs on a JDK, so better use the jdk version. Also for JAI check you have the latest version, if not install it also, because this can be really the problem (an old version of JAI -> 1.0 version).
Jose García.
Sent: Tuesday, September 15, 2009 5:06 PM
hi josegar,
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
in
be
Jose García
stay
now&#33;
now&#33;
Can I download and install the Java package without deinstall the old one?
Thanks for your help! I will try this out.
best regards
Sarah
lead you there.
Good luck.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
hi josegar,
one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
installed
in
be
installed.
Jose García
your
stay
now&#33;
now&#33;
now&#33;
now&#33;
View this message in context: http://n2.nabble.com/Fw-Geoserver-with-Tomcat-map-not-shown-tp3649521p3649800.html
Yes, you sure can.
Just be sure that you set an enviornment variable pointing to wherever you install it
I think in Windows you go to Control Panel->System->Advanced->Enviornment Variables
In "System Variables", click new and the add
Variable name: JAVA_HOME
Variable value: Path to the JDK, (Something like.."C:\Sun\jdk\bin")
Hope this helps.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
Sent: Tue 2009-09-15 17:37
best regards
Sarah
lead you there.
Good luck.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
hi josegar,
one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
installed
in
be
installed.
Jose García
your
stay
now&#33;
now&#33;
now&#33;
now&#33;
At sun homepage there is java jdk 6 update 16 which I already have
(1.6.0_16-b01). So I think I don´t need to download it. Or do you mean the
JDK 6 Update 16 with Java EE installation?
I don´t understand why geoserver would not work with the geoserver came with
GN. I will try to download a new version of geoserver.
I take a look at the jai´s version (how? with a command? at the folder?).
Thanks!
best regards
Sarah
best regards
Sarah
lead you there.
Good luck.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
hi josegar,
one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
installed
in
can
be
installed.
Jose García
your
stay
now&#33;
stay
now&#33;
now&#33;
now&#33;
View this message in context: http://n2.nabble.com/Fw-Geoserver-with-Tomcat-map-not-shown-tp3649521p3649916.html
I have installed the Java SDK and set the Path, then downloaded and
installed latest geoserver but I get an error /geoserver could not be
started. It´s frustrating.
Jose, after I installed the I/O Tools, picture at the middle of the start
site of geonetwork was missing. And didn´t come when I deinstalled those.
Really strange I think. So I didn´t installed any further JAIs (although
Jason said I haven´t to).
I will ask at the geoserver forum too, perhaps they could give me a hint or
tip.
I will let you know if I found a solution for my problem.
Thanks.
Sarah
Yes, you sure can.
you install it
Variables
Hope this helps.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
best regards
Sarah
lead you there.
(just
Good luck.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
hi josegar,
one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
you
have now installed.
Jose García
Hi josegar,
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
installed
in
can
be
installed.
Jose García
your
stay
now&#33;
stay
now&#33;
now&#33;
now&#33;
now&#33;
now&#33;
View this message in context: http://n2.nabble.com/Fw-Geoserver-with-Tomcat-map-not-shown-tp3649521p3654890.html
I want to let you know that I found my mistake:
after I downloaded new Java jdk and set classpath (and furthermore set
classpath to geoserver data dir) it still didn´t worked. So I looked at
Tomcat properties (on win: tomcat6w.exe) and found the reason:
my jave virtual machine was linked to my old jre/jdk version (so there was
no jai_core and I could not see a image). So I linked it to my new
jdk1.6\jre\bin\client and it worked.
Thanks for your replies!
best regards
Sarah
Sarah_S wrote:
or tip.
Thanks.
Sarah
Yes, you sure can.
you install it
Variables
Hope this helps.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
one?
best regards
Sarah
necessary.
will
lead you there.
where
(just
problems
Good luck.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
hi josegar,
one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
LICENSE
case
you
have now installed.
Jose García
Hi josegar,
at
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
installed
in
can
be
installed.
Jose García
CA
your
stay
now&#33;
your
stay
now&#33;
stay
now&#33;
stay
now&#33;
now&#33;
now&#33;
View this message in context: http://n2.nabble.com/Fw-Geoserver-with-Tomcat-map-not-shown-tp3649521p3667886.html
jdk1.6\jre\bin\client and it worked. :slight_smile:
best regards
Sarah
Sarah_S wrote:
or tip.
Thanks.
Sarah
Yes, you sure can.
you install it
Variables
Hope this helps.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
one?
best regards
Sarah
necessary.
will
lead you there.
where
(just
problems
Good luck.
Jason
Jason P. Pickering
Consultant
tel: +260968395190
hi josegar,
one
should I use?
Thanks!
Best regards
Sarah
josegar74 wrote:
Hi Sarah
JAI:
mlib_jai.dll
mlib_jai_mmx.dll
LICENSE-jai.txt
I/O Tools:
clib_jiio.dll
LICENSE
case
you
have now installed.
Jose García
Hi josegar,
at
Thanks
Best regards
sarah
josegar74 wrote:
Hi Sarah
Check if JAI 1.1.X
installed
in
can
be
installed.
Jose García
CA
your
stay
now&#33;
your
stay
now&#33;
stay
now&#33;
stay
now&#33;
now&#33;
now&#33;
View this message in context: http://n2.nabble.com/Fw-Geoserver-with-Tomcat-map-not-shown-tp3649521p3667892.html
