Hi Giuliani,
That upgrade should be easy. In fact, the version installed with GeoNetwork is a version that only has some of the demo data removed and two layers have been configured for GeoNetwork, otherwise it is not customized.
You could install GeoServer somewhere on your system and configure the two layers on that instance. The link between the GeoNetwork map viewer and the GeoServer layers is configured in ../web/intermap/WEB-INF/mapServers.xml
The main thing to take care of is that GeoNetwork and GeoServer run on the same web server (and thus with the same port), or in separate web servers with different ports.
Let me know if you need more assistance.
Ciao,
Jeroen
____________________________________________________
Jeroen Ticheler
FAO-UN
NRC - Room F817
Viale delle Terme di Caracalla, 00153 Rome - Italy
Tel/Fax: +39 06 570 56041/53369
http://www.fao.org/geonetwork
On Jun 9, 2008, at 10:02 AM, giuliani@anonymised.com wrote:
You are receiving this mail because Gregory Giuliani
Hello, I'm testing GeoNetwork and it's really a nice application! Many thanks for providing us such a usefull tool. Now I have a small question, I want to upgrade the embedded GeoServer with the new version. How could I easily upgrade? Many thanks for your help. Kind regards Gregory Giuliani UNEP/DEWA/GRID-Europe
GeoNetwork opensource Administrator
