Hey Thank you so much Gracia
Finally Geoserver started and maps are also displayed in FireFox, but in
IE9 there still only header displays.
Any idea about why it does not display anything in IE9?
And it also does not show the default data that is in geonetwork, do you
know the reason?
Kind Regards,
*To:* saher murad <sahermurad@anonymised.com>
*Cc:* "geonetwork-users@lists.sourceforge.net" <
geonetwork-users@lists.sourceforge.net>
*Sent:* Monday, 2 July 2012, 13:04
*Subject:* Re: [GeoNetwork-users] Geoservercannot be started in
Geonetwork 2.6.4
Hi Saher
Seem related to geowebcache in geoserver app. Please try this, go to
data/geoserver_data and remove the folder gwc. Restart GeoNetwork and
hopefully should work ok.
Jose García
On Mon, Jul 2, 2012 at 10:01 AM, saher murad <sahermurad@anonymised.com> wrote:
Hi Gracia,
Thank you for your time and quick response.
I have installed in E:\geonetwork
And the log file gives following error:
Instantiation of bean failed; nested exception is
org.springframework.beans.BeanInstantiationException: Could not instantiate
bean class [org.geowebcache.config.XMLConfiguration]: Constructor threw
exception; nested exception is
com.thoughtworks.xstream.converters.ConversionException: Cannot construct
org.geowebcache.layer.wms.WMSLayer as it does not have a no-args
constructor : Cannot construct org.geowebcache.layer.wms.WMSLayer as it
does not have a no-args constructor
---- Debugging information ----
message : Cannot construct org.geowebcache.layer.wms.WMSLayer
as it does not have a no-args constructor
cause-exception :
com.thoughtworks.xstream.converters.reflection.ObjectAccessException
cause-message : Cannot construct org.geowebcache.layer.wms.WMSLayer
class : org.geowebcache.config.GeoWebCacheConfiguration
required-type
I cannot figure out what is exactly causing this error, Please could you
help me further with it.
Kind Regards,
Saher
*To:* Saher Murad <sahermurad@anonymised.com>
*Cc:* geonetwork-users@lists.sourceforge.net
*Sent:* Monday, 2 July 2012, 12:20
Geonetwork 2.6.4
Hi Saher
The installer for 2.6.4 only includes the package Core, the packages you
describe are available for 2.8.0 version that is not stable yet. You can
find the RC0 here:
http://sourceforge.net/projects/geonetwork/files/GeoNetwork_unstable_development_versions/v2.8.0RC0/
About the error, please check in jetty/logs the files output.log and
geonetwork.log to get more information about the cause of error. Also check
you didn't install in Program Files folder, this causes several issues with
permissions, so better to install in a folder like c:\geonetwork instead.
Jose García
On Mon, Jul 2, 2012 at 8:54 AM, Saher Murad <sahermurad@anonymised.com> wrote:
I have installed Geonetwork 2.6.4 on system with following specs:
System type: 64 Bit
Windows 7 Professional, Service Pack 1
Following JRE is also installed:
jre1.5.0_22
jre6
When installing geonetwork 2.6.4 the installation pack only includes 'Core'
& it does not include
- GeoNetwork User Interface
- GeoServe
- European Union INSPIRE Directive configuration pack
After starting the geonetwork server, only header is displayed in IE 9 &
Maps are not displayed in Firefox 13.0.1 & Googloe Chrome 19.
http://localhost:8080/geoserver gives error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/geoserver
Powered by jetty://
Please could someone help me with the above problem.
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Geoservercannot-be-started-in-Geonetwork-2-6-4-tp4985225.html
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net/>
