[GeoNetwork-users] Getting GAST to work / importing-exporting records
Hi there,
I'm getting the following error in GAST:
JDOM Parse Exception. Error on line 1 of document /home/user ..../WEB-INF/:
Content in not allowed in prolog.
My previousGastConfig.properties file:
#This file contains the configuration from the previous GAST execution
#Wed Jun 29 17:12:26 ICT 2011
schemas=/home/user/geonetwork/web/geonetwork/xml/schemas
setup-config=/home/user/geonetwork/web/geonetwork/WEB-INF/classes/setup
logOutputDir=/home/user/geonetwork/jetty/logs
config-xml=/home/user/geonetwork/web/geonetwork/WEB-INF
embedded-db=/home/user/geonetwork/web/geonetwork/WEB-INF/db
conversions=/home/user/geonetwork/web/geonetwork/xsl
webapp=/home/user/geonetwork/web
logos=/home/user/geonetwork/web/geonetwork/images/logos
web-xml=/home/user/geonetwork/web/geonetwork/WEB-INF
templates=WEB-INF/classes/setup/templates
jetty-port=80
sample-data=/home/user/geonetwork/gast/setup/sample-data
I'd be grateful for any ideas.
I want to use GAST for exporting/importing records. Alternatively I've found
the easiest way is to insert exported ZIP (MEF?) files via the
Administration page and to export from the results list.
Richard
v2.6.3
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-GAST-to-work-importing-exporting-records-tp6528379p6528379.html
Okay, got this working without too much trouble.
Instead of inserting paths for all of the items, just insert
webapp=/home/user/geonetwork/web/geonetwork
for the initial configuration.
GAST will open and then click on 'options' and complete all fields.
Richard
ref:
http://osgeo-org.1803224.n2.nabble.com/metadata-export-error-in-GAST-anyone-td6357284.html#a6395904
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-GAST-to-work-importing-exporting-records-tp6528379p6528722.html
