To get started with configuration override i tried to rename a tab in the strings.xml file.
So i edited the content of the "config-overrides.xml" file in the WEB-INF folder.
The content of the "config-overrides.xml" file is now:
<overrides>
<file name=".*loc/ger/xml/strings.xml">
<replaceText xpath="//porCatInfoTab">Test</replaceText>
</file>
</overrides>
No changes appeared..
First guess, you forgot a slash :
<file name=".*/loc/ger/xml/strings.xml">
should be better, I believe.
Jean
WEB-INF folder.
<overrides>
</file>
</overrides>
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
GeoNetwork-users mailing list
I added the slash.
Stil not working.
Am 04.07.2014 15:44, schrieb Jean Pommier:
Jean
WEB-INF folder.
<overrides>
</file>
</overrides>
