[GeoNetwork-users] Ghosts in the machine... CSW finds records that don't exist!
After running a harvest of published records to data.gov.uk I see in their harvest log two errors relating to empty records:
GUID: 2303dffc-3298-4237-bb02-34f2ecb672df
Empty record for GUID 2303dffc-3298-4237-bb02-34f2ecb672df
GUID: f46c2fc8-4fd1-4737-a57e-ef9ca83c68e8
Empty record for GUID f46c2fc8-4fd1-4737-a57e-ef9ca83c68e8
And indeed they are empty:
http://metadata.bgs.ac.uk/geonetwork/srv/en/csw?SERVICE=CSW&REQUEST=GetRecordById&elementSetName=full&OutputSchema=http://www.isotc211.org/2005/gmd&ID=2303dffc-3298-4237-bb02-34f2ecb672df&
http://metadata.bgs.ac.uk/geonetwork/srv/en/csw?SERVICE=CSW&REQUEST=GetRecordById&elementSetName=full&OutputSchema=http://www.isotc211.org/2005/gmd&ID=f46c2fc8-4fd1-4737-a57e-ef9ca83c68e8&
A CSW request for all published records tells me I have 357 records...
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd&quot;&gt;
  <csw:SearchStatus timestamp="2012-01-27T13:56:28" />
  <csw:SearchResults numberOfRecordsMatched="357" numberOfRecordsReturned="10" elementSet="summary" nextRecord="11" />
</csw:GetRecordsResponse>
My problem is as far as I know I should only have 355 records!
My system has three categories: datasets, interactiveResources, TEST-ONLY which give the following results:
http://metadata.bgs.ac.uk/geonetwork/srv/en/main.search.embedded?category=datasets (338 records)
http://metadata.bgs.ac.uk/geonetwork/srv/en/main.search.embedded?category=interactiveResources (17 records)
http://metadata.bgs.ac.uk/geonetwork/srv/en/main.search.embedded?category=TEST-ONLY (0 records)
I just can't work out where the empty records are hiding, does anyone have any ideas?
Thanks
James
James Passmore
GIS and WWW Specialist
Information Systems and Infrastructure,
British Geological Survey,
http://www.bgs.ac.uk/
+44 (0)115 936 3125
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
