[GeoNetwork-users] GN 2.10 problem uploading thumbnails
When attempting to add a thumbnail to GeoNetwork 2.10.2 I get a nullpointerexception error.
I checked the list but don't see this specific issue. This is just using the normal web editor logged in as admin.
Wondering if there is a permissions issue somewhere on my server (this is a newly migrated instance -- used to work fine with the 2.8 version).
Thoughts of things I can try to resolve?
Kathy
_____________________________________
Kathy Koch
Data Curator
Contractor (LimnoTech / GLOS)
501 Avis Drive, Ann Arbor, MI 48108
Office: 734-332-1200 email:kkoch@anonymised.com<mailto:kkoch@anonymised.com>
LimnoTech www.limno.com<https://mail.limno.com/owa/UrlBlockedError.aspx&gt;
<../../../../tdekker/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/8B0OUOWO/www.limno.com>
Thanks Jean! I'd actually found it just before your helpful message came through. Does look like I have a permissions issue so have asked the system admin to fix that and then we will see if GN will behave.
Although I also found out that my images are pointing to the old instance (thankfully my admin hasn't disabled that 'yet'). Do you know which config file that setting might be in? The images are definitely on the new server as well so I'm guessing it is just a setting somewhere.
Kathy
Kathy Koch
Data Curator
Sent: Thursday, March 19, 2015 4:52 PM
To: Kathy Koch
Subject: Re: [GeoNetwork-users] GN 2.10 problem uploading thumbnails
Of course !
First, you must check the place of your data directory. for that, if you're not sure, you can look in the Admin page, go to System Information, Data directory:
It will end with something liek data/metadata_data.
In this folder, you have several folders named in a 00x00-00x99 and in those folders, you have numeric sub-folders. Each one of these subfolders corresponds to a metadata entry. It is not the UUID but an Id used internally for geonetwork. I believe it's the row id in the DB.
In each of these folders, you have 2 subfolders : 'public' and 'private'.
In private will be the data uploaded and associated to the metadata
In public will be the thumbnails.
So, let's says you have a metadata with UUID b2e4ed86-815e-4618-a986-3c7443cd7ce1. To find the matching ID, you may look in the DB, or look closely at the queries performed in the user interface. I believe I remember some of them use the ID.
Let's say you found the matching ID in your DB is 581. You will look in .../data/metadata_data/00500-00599/581/public to see if the tumbnail is there.
Of course, ideally, your tomcat user is owner of the whole .../data directory, hence metadata_data and all its subfolders. If not, it can quickly get messy.
I hope this will help !
Have a good night,
cheers,
Jean
[cid:part1.01090401.00090708@anonymised.com]
Jean Pommier -- pi-Geosolutions
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com<mailto:jp@anonymised.com>
Web : www.pi-geosolutions.fr<http://www.pi-geosolutions.fr>
Le 19/03/2015 17:37, Kathy Koch a écrit :
I have had some issues with that, but I can't even figure out at this point what folder the thumbnails are in. Can you point me in the right direction?
Kathy
Kathy Koch
Data Curator
<UrlBlockedError.aspx>
From: Jean Pommier [jean.pommier@anonymised.com<mailto:jean.pommier@anonymised.com>]
Sent: Thursday, March 19, 2015 12:24 PM
To: Kathy Koch
Hi Kathy,
I suppose you checked your tomcat instance (or jetty or whatelse) has write access to your geonetwork data directory ?
[cid:part5.07010400.02030309@anonymised.com]
Kathy
Kathy Koch
Data Curator
Office: 734-332-1200 email:kkoch@anonymised.com<mailto:email:kkoch@anonymised.com…><mailto:kkoch@anonymised.com><mailto:kkoch@anonymised.com>
LimnoTech www.limno.com<http://www.limno.com><https://mail.limno.com/owa/UrlBlockedError.aspx&gt;&lt;https://mail.limno.com/owa/UrlBlockedError.aspx&gt;
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@anonymised.comforge.net>
(attachments)
Hi Kathy,
That depends how it has been configured.
In my case, I configured it in tomcat's server.xml config file.
But it can be configured in the Java OPTs too, or in one of the xml config files of your GN instance
But... if the new thumbnails are placed in the new GN instance... i would say it's more about adjusting the path settings in the metadata records. You have to check everything is right in the admin/System Configuration folder.
I believe normally, GN should adjust the paths in the metadata records correspondingly.
If not, you still can perform an update query in your database, directly.
*Jean Pommier -- pi-Geosolutions*
