[GeoNetwork-users] GN 2.6.0 Import Metadata from ArcCatolog (Arc_8_to_Iso.xsl)
Hi
We have been facing something weird in the process of integrating medatata
sheets from ArcCatzlog (9.3) to Geonetwork. When exporting, from the
metadata wizard (iso) tools in XML format, the importation aways leads to
the same error "Root element not set) (with the option "ArcCatlog_8_to Iso)
and new UUID when we select the xml file. But the importation works when we
copy and paste the contents of the files in the "window" area of GN ?
Is there an option we are missing or an updated version of the xsl file for
such importation ?
Regards
Laurent Drapeau
Hello Laurent, this is a bug in 2.6.0 which will be fixed in coming 2.6.1.
See http://trac.osgeo.org/geonetwork/ticket/344
Cheers.
Francois
2010/11/16 laurent drapeau <laurent.drapeau@anonymised.com>:
Hi
such importation ?
Regards
Laurent Drapeau
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
GeoNetwork-users mailing list
