Hello group. I am one of the engineers who is evaluating GN as the GISC
portal for the US National Weather Service as part of the WMO WIS
initiative.
I have been having several issues that Timo has been graciously trying to
help with but I am now going to start addressing my concerns to the
community. Please bear with me.
First problem:
I have a GN 2.6.3 node at http://140.90.88.137:8080/geonetwork. This node
I will call the internal GN node. This is the node the metadata managers
will manage their metadata. It has one data set called NWS. It has one
record that is set to publicly viewable.
I have another GN 2.6.3 node where I am trying harvest that record into.
The point of all this is that I plan to have an external GN node where I
will allow public search to not only this harvested data but all other
datasets from other GISC centers.
I have setup up the harvest as Geonetwork Node 2.1 harvest and can
successfully retrieve the source NWS in the harvest setup.
When I run the harvest the result is )when hovering over the green check
mark) is 0 for for all 7 results and the last run result does indicate it
ran.
What additional information can I provide to help you help me? logs, the xml
for the one records? Let me know.
Thanks.
cd
Craig Donahue
Program Manager
Prism Communications Inc..
443-742-4316
Craig Donahue
Program Manager
443-742-4316
