[GeoNetwork-users] GN 21 beta bugs?
HI all,
I am testing the GN 21 beta on a linux box using tomcat and MySQL.
I have to change the script for creating a database used by GASt, there was
a problem with the field label of the table called ISOsomething (sorry
cannot remeber the name now). In fact the script creates a table where label
is varchar(64) but after inser inside the table records where the label
attribute is longer than that. Changing the length og the lable field to 255
makes the script work correctly.
Is thia a bug?
I am also experiencing a problem with th add user web interface. I have an
error when I try to add a new user. In aprticular clicking on SAVE button I
have a JS error:
var profile = $F('user.profile');
Any other users is experiencing the same js problem?
Thanks
Simone Gadenz
_________________________________________________
European Commission
Joint Research Center
Institute for the Protection and Security of the Citizen (IPSC)
Support to External Security
CCR - TP267, Via E. Fermi 1, 21020 Ispra, VA, Italia
Phone: +39-0332-786968 - Fax: +39-0332-785154
simone.gadenz@anonymised.com
Disclaimer: Views expressed are those of the individual and do not represent
the views of the European Commission
(attachments)
Hi Simone,
HI all,
Is thia a bug?
Yes, it is a bug and has been fixed now. The problem was related to the
embedded dbms which did not rise the error.
have a JS error:
There is a missing prototype.js inclusion in both user editing and metadata
creation pages. They have been fixed in beta3 so try that one (but maybe
the first bug is still there).
Thanks
Simone Gadenz
PS: I tried to answer you but my emails came back. Here was my answer:
you need Java 1.5 from Sun. Java 6 has not been tested. Regarding Tomcat,
any version >= 5.5 should be ok.
What is the java and tomcat versions required to run the GN 2.1 beta? Sorry
for asking but I couldn't find this information on the website. In case it
was there may somebody send me a refernce to that page? Thanks
Simone Gadenz
Hi Andrea,
Indeed the first one is still there. I wanted to move the prototype link to the header.xsl file, but didn't have the opportunity to change it yet.
Ciao,
Jeroen
On Jun 8, 2007, at 4:42 PM, Andrea Carboni wrote:
Hi Simone,
HI all,
Is thia a bug?
have a JS error:
Thanks
Simone Gadenz
Simone Gadenz
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Do you think it is possible to include the prototype.js in the existent beta
2 pages? Or is better to reinstall the beta 3?
Also, to share with other users, I had a problem trying to make the beta 2
working on mysql database. The GAST tool kept throwing an error saying the
mysql driver was missing. After trying to reference the driver for Tomcat
the only way to make it work was to put it into the folder
geonetwork/web/WEB-INF/lib following the paper at
http://mimis.simos.googlepages.com/Geonetworksetupsupportingmulti-langu.pdf.
I don't know whether it is a problem relating to the Linux distro I am using
(Gentoo) or if it is something it should be done in any case.
Simone
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of Andrea
Carboni
Sent: Friday, June 08, 2007 4:43 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] GN 21 beta bugs?
Hi Simone,
HI all,
there was a problem with the field label of the table called
ISOsomething (sorry cannot remeber the name now). In fact the script
creates a table where label is varchar(64) but after inser inside the
table records where the label attribute is longer than that. Changing
the length og the lable field to 255 makes the script work correctly.
Is thia a bug?
have an error when I try to add a new user. In aprticular clicking on
SAVE button I have a JS error:
creation pages. They have been fixed in beta3 so try that one (but maybe the
Thanks
Simone Gadenz
Sorry for asking but I couldn't find this information on the website.
In case it was there may somebody send me a refernce to that page?
Thanks
Simone Gadenz
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the
FREE version of DB2 express and take control of your XML. No limits. Just
Ciao Simone,
Yes. Edit the file web/xsl/header.xsl and add the prototype inclusion just after
the line:
<script type="text/javascript" src="{/root/gui/url}/scripts/form_check.js"/>
Actually it is not a bug. Up to now, geonetwork has the jdbc drivers for the
embedded dbms (mckoi) and for postgresql. Maybe we should add the drivers
for mysql and oracle but this has some drawbacks:
- the application gets bigger as soon as more drivers are added
- the drivers should be kept in sync
- drivers not supported must still be downloaded and copied into WEB-INF/lib
- a not skilled user could have problems trying to upgrade a non recent driver
  because he could not remove the old one.
It is not clear to me which is the best strategy.
Simone
Carboni
Hi Simone,
> HI all,
> Is thia a bug?
> Thanks
> Simone Gadenz
> Hi all,
> Thanks
> Simone Gadenz
