Dear all,
the GeoNetwork GUI 3.0.1 obviously has a problem concerning harvesting.
I have three harvesting knodes configured an can see them in the Harvester:
- first node CSW
- second node CSW
- third node CSW
I press the button in order to remove the metadata from the second node. The
yellow button below the Harvester-list shows "Remove xxx records". That´s
fine.
Now I click the first node. The yellow button still shows Remove! But it
takes the number of metadata from the first node. - I did not want to delete
those
Now I click the third node. The yellow button still shows Remove! But it
takes the number of metadata from the third node... oh dear?!
After an hour of waiting for removing god-knows-which records from the
second node, we had a restart of tomcat. Result: Metadata from second node
has been removed sucessfully. Metadata from first and third node were still
there. Very good! It´s just the GUI with some kind of minor problem.
The GUI from the Harvester does not show, if it has finished removing
metadata. The yellow button sticks to "Remove xxx records". It should show,
that the process has ended successfully if the process has come to an end. -
Could somebody please fix that for the next release? Thank you
Greetings,
Anja
View this message in context: http://osgeo-org.1560.x6.nabble.com/GN-3-0-1-GUI-problem-in-harvester-yellow-button-remove-xxx-records-tp5217732.html
