[GeoNetwork-users] GN 3.0.2 and multinode: trouble
Hello
With GN 3.0.2, i can switch between two nodes, but it seems that the specific configuration for the database isn't understood by GN.
What i did is:
    deploy the geonetwork3.0.2.war in tomcat8
    start GN with the default configuration except for the datadir
    stop tomcat
    add a servlet-mapping section for the new node at the end of
    WEB-INF/web.xml
    create a node.xml in WEB-INF/config-node, containing database parameters
    copy an existing datadir from a previous GN installation i want to
    upgrade in a folder node (inside the datadir)
    start tomcat
I was expecting messages in the log about the migration of the database
When i switch to the new node, i obtain an empty Gn catalog.
My switching, i mean replacing "srv" by "nodename" in the default URL.
Am i missing something ?
Thank for your help
Philippe
Re: Publication profil geonetwork
Found the mistake: forgot to move the node.xml file in WEB-INF/config-node
folder !
I also used the script node-mgr.sh as presented in this page
<http://geonetwork-opensource.org/manuals/trunk/eng/users/maintainer-guide/installing/using-multinode-mode.html&gt;
But I needed to edit this script and change the value of the WEB_FILE_OUT
variable which got the same value of the WEB_FILE variable. This simply
conduce to delete the WEB-INF/web.xml file, which is not what is expected.
After this change, the script worked perfectly.
pclastre wrote
Hello
What i did is:
    stop tomcat
    WEB-INF/web.xml
parameters
    start tomcat
Thank for your help
Philippe
GeoNetwork-users mailing list
GeoNetwork-users@anonymised.com
View this message in context: http://osgeo-org.1560.x6.nabble.com/GN-3-0-2-and-multinode-trouble-tp5233167p5234071.html
Thanks for reporting. Fixed in
https://github.com/geonetwork/core-geonetwork/commit/ff733def4df2967a2f5c00b452554e671b6d223a
Francois
2015-11-03 8:54 GMT+01:00 pclastre <Philippe.Clastre@anonymised.com>:
WEB-INF/config-node
folder !
pclastre wrote
> Hello
> What i did is:
> stop tomcat
> WEB-INF/web.xml
> parameters
> start tomcat
> Thank for your help
> Philippe
