On Fri, Jan 13, 2017 at 9:58 AM, hoddih <hoddi@anonymised.com> wrote:
Hi......again
I'm trying to made some little changes in the view and I can't find where
and how i do a css changes!
Do I need to restart the service after changes and/or delete any cache?
I'm using GN 3.0.4
Regards, Hoddi
View this message in context: http://osgeo-org.1560.x6.
nabble.com/GN-3-0-4-CSS-tp5303304.html
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-users
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
Have you try with the ?debug param in the url? To verify if maybe a issue
of the wro4j cache (in debug mode no wro4j cache is used and I guess should
be picked the change).
If works in debug mode, check in the Administration page > Tools to cleanup
the wro4j cache, at least in 3.2.x there's an option to clear JS/CSS cache,
but not sure if also it's available in 3.0.x.
Jose García
On Fri, Jan 13, 2017 at 10:31 AM, hoddih <hoddi@anonymised.com> wrote:
Thanks Jose
I have tried to made change there but the changes don't goes through.
The htm changes is no problem.
I am trying to make this change:
.col-md-9 {
width: 75%; to 85%
It seems to
nabble.com/GN-3-0-4-CSS-tp5303304p5303310.html
projects/geonetwork
On Fri, Jan 13, 2017 at 9:53 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
cleanup the wro4j cache, at least in 3.2.x there's an option to clear
JS/CSS cache, but not sure if also it's available in 3.0.x.
Jose García
Thanks Jose
.col-md-9 {
width: 75%; to 85%
It seems to
View this message in context: http://osgeo-org.1560.x6.nabbl
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
On Fri, Jan 13, 2017 at 11:25 AM, Hólmgrímur Helgason <hoddi@anonymised.com434...> wrote:
Hello Jose
If I use the ?debug param i get empty result page. http://geo.abds.is/
geonetwork/srv/eng/catalog.search#/search?debug
GN 3.0.4 don't have this clean up button
wrote:
Hi
Jose García
Thanks Jose
.col-md-9 {
width: 75%; to 85%
It seems to
s/geonetwork
wrote:
Hi
issue of the wro4j cache (in debug mode no wro4j cache is used and I guess
should be picked the change).
Jose García
Thanks Jose
.col-md-9 {
width: 75%; to 85%
It seems to
s/geonetwork
I see some javascript errors when using the debug mode. Not very clear if
it's a issue in 3.0.4, but usually both debug and no debug modes should
work.
Jose García
On Fri, Jan 13, 2017 at 11:46 AM, Hólmgrímur Helgason <hoddi@anonymised.com434...> wrote:
Hi
The I get just clean white page - http://geo.abds.is/
geonetwork/srv/eng/catalog.search?debug#/home
On Fri, Jan 13, 2017 at 10:42 AM, Jose Garcia <jose.garcia@anonymised.com>
wrote:
Hi
Use ?debug before the #
Jose García
On Fri, Jan 13, 2017 at 11:25 AM, Hólmgrímur Helgason <hoddi@anonymised.com..1434...>
wrote:
Hi
Jose García
Thanks Jose
.col-md-9 {
width: 75%; to 85%
It seems to
s/geonetwork
You can remove wro4j cache from admin console / tools
On Fri, Jan 20, 2017 at 11:56 AM, hoddih <hoddi@anonymised.com> wrote:
Solved
I needed to turn of tomcat and manualy delete
"../webapps/geonetwork/WEB-INF/data/wro4j-cache*
Then I could change the javascript and add extra style in "gn_view.less"
Thanks for you helps
nabble.com/GN-3-0-4-CSS-tp5303304p5304162.html
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users@lists.sourceforge.net geonetwork-users List Signup and Options
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
