I have just installed GN3.10 in a ubuntu server 18.04 with tomcat9.
Java is openjdk version8.
I configured postgresql db.
Unfortunately it doesn't work, I got this errors in geonetworks.log:
2020-08-03 10:20:38,286 ERROR [jeeves] - JeevesContextLoaderListener: Error creating bean with name 'org.fao.geonet.kernel.datamanager.draft.DraftMetadataIndexer#0': Unsatisfied dependency expressed through field 'searchManager': Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'org.fao.geonet.kernel.datamanager.draft.DraftMetadataIndexer#0': Unsatisfied dependency expressed through field 'searchManager': Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:573)
at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:88)
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1214)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:543)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:775)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:861)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:541)
at jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:81)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4668)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5136)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:713)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:695)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:978)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1850)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:773)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:427)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1577)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:424)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:367)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:929)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:831)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1377)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1367)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:902)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:423)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:928)
at org.apache.catalina.startup.Catalina.start(Catalina.java:638)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:350)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:496)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1105)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1050)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
at org.springframework.beans.factory.config.DependencyDescriptor.resolveCandidate(DependencyDescriptor.java:187)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:1208)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:1048)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:1018)
at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:570)
... 54 more
Caused by: java.lang.ExceptionInInitializerError
at org.geotools.xml.Schemas.parse(Schemas.java:302)
at org.geotools.xml.Schemas.parse(Schemas.java:294)
at org.geotools.xml.Schemas.parse(Schemas.java:256)
at org.geotools.gml3.v3_2.GML.buildSchema(GML.java:2732)
at org.geotools.xml.XSD.getSchema(XSD.java:232)
at org.geotools.gml3.v3_2.GML.<init>(GML.java:71)
at org.geotools.gml3.v3_2.GML.<clinit>(GML.java:55)
at org.geotools.gml3.v3_2.GMLConfiguration.<init>(GMLConfiguration.java:122)
at org.geotools.gml3.v3_2.GMLConfiguration.<init>(GMLConfiguration.java:114)
at org.geotools.filter.v2_0.FESConfiguration.<init>(FESConfiguration.java:116)
at org.fao.geonet.kernel.search.SearchManager.<clinit>(SearchManager.java:157)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:89)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1098)
... 66 more
Caused by: java.lang.IllegalArgumentException: org.geotools.styling.StyleFactory is not an ImageIO SPI class
at java.desktop/javax.imageio.spi.ServiceRegistry.checkClassAllowed(ServiceRegistry.java:722)
at java.desktop/javax.imageio.spi.ServiceRegistry.<init>(ServiceRegistry.java:117)
at org.geotools.factory.FactoryRegistry.<init>(FactoryRegistry.java:155)
at org.geotools.factory.FactoryCreator.<init>(FactoryCreator.java:91)
at org.geotools.factory.CommonFactoryFinder.getServiceRegistry(CommonFactoryFinder.java:76)
at org.geotools.factory.CommonFactoryFinder.lookup(CommonFactoryFinder.java:346)
at org.geotools.factory.CommonFactoryFinder.getFilterFactory(CommonFactoryFinder.java:300)
at org.geotools.factory.CommonFactoryFinder.getFilterFactory2(CommonFactoryFinder.java:390)
at org.geotools.factory.CommonFactoryFinder.getFilterFactory2(CommonFactoryFinder.java:404)
at org.geotools.data.DataUtilities.<clinit>(DataUtilities.java:205)
... 84 more
2020-08-03 10:20:38,298 FATAL [jeeves.engine] - Raised exception during init
2020-08-03 10:20:38,299 FATAL [jeeves.engine] - Exception : org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'org.fao.geonet.kernel.datamanager.draft.DraftMetadataIndexer#0': Unsatisfied dependency expressed through field 'searchManager': Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
2020-08-03 10:20:38,300 FATAL [jeeves.engine] - Message : Error creating bean with name 'org.fao.geonet.kernel.datamanager.draft.DraftMetadataIndexer#0': Unsatisfied dependency expressed through field 'searchManager': Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
2020-08-03 10:20:38,303 FATAL [jeeves.engine] - Stack : org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'org.fao.geonet.kernel.datamanager.draft.DraftMetadataIndexer#0': Unsatisfied dependency expressed through field 'searchManager': Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'SearchManager' defined in URL [jar:file:/var/lib/tomcat9/webapps/geonetwork/WEB-INF/lib/core-3.10.3-0.jar!/config-spring-geonetwork.xml]: Instantiation of bean failed; nested exception is java.lang.ExceptionInInitializerError
... 54 more
... 66 more
... 84 more
Do you have any suggestions?
I read some threads on the compatibility of GN with tomcat9,
which was not so clear, e.eg., http://osgeo-org.1560.x6.nabble.com/GN-3-8-install-td5430822.html
Does anyone is experienced?
Eugenio
I finally figured out the configuration of GN 3.10.3 with java8.
However, I wonder if anybody experienced GN 3.10.3 with higher java versions.
I look forward for your feedback,
Eugenio
Da: Eugenio Trumpy
Inviato: lunedì 3 agosto 2020 10:23
A: Lista Geonetwork <geonetwork-users@lists.sourceforge.net>
Oggetto: GN 3.10 and tomcat9
... 54 more
... 66 more
... 84 more
... 54 more
... 66 more
... 84 more
Eugenio
Hi Eugenio,
On Tue, Aug 4, 2020 at 2:05 PM Eugenio Trumpy <frippe12573@anonymised.com>
wrote:
versions.
GeoNetwork currently needs Java 8 to run. Check this page about the
migration to Java 11 migration status [1].
[1] https://github.com/geonetwork/core-geonetwork/wiki/Java-11-Compatibility
*Vriendelijke groeten / Kind regards,Juan Luis RodrÃguez.
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
