Hi Evert
The mandatory stuff is controlled mainly in this code:
https://github.com/geonetwork/core-geonetwork/blob/3.2.x/web/src/main/webapp/xslt/ui-metadata/form-builder.xsl#L108-L119
for all metadata profiles.
In that snippet is check if the cardinalities of the parent (if available)
or from the element. This is usually not useful at all as in some profiles
you want to set mandatory elements also for elements that are optional in
the xsd.
For some projects we have extended to take also the mandatory conditions
from labels.xml, so for example in this case Use Constraints will get the
mandatory indicator:
<element id="71.0" name="gmd:useConstraints">
<label>Use Constraints</label>
<description></description>
* <condition>mandatory</condition>*
</element>
Code snippet updated:
<xsl:variable name="isRequired" as="xs:boolean">
<xsl:choose>
<xsl:when
test="($parentEditInfo and $parentEditInfo/@min = 1 and
$parentEditInfo/@max = 1) or
(not($parentEditInfo) and $editInfo and $editInfo/@min = 1 and
$editInfo/@max = 1)">
<xsl:value-of select="true()"/>
</xsl:when>
* <xsl:when test="gn-fn-metadata:getLabel($schema, name(),
$labels)/condition = 'mandatory'">*
* <xsl:value-of select="true()"/>*
* </xsl:when>*
<xsl:otherwise>
<xsl:value-of select="false()"/>
</xsl:otherwise>
</xsl:choose>
</xsl:variable>
I'll check with other developers for any comment about the code and to
commit it.
Jose García
On Tue, Feb 21, 2017 at 12:56 AM, Bleys, Evert <
Evert.Bleys@anonymised.com> wrote:
Hi Guys
Start with an apology: I suspect this has been discussed earlier
Note: I'm using ISO19115-3 as my base metadata standard
I have inherited a v3.2 editing interfaces.
There are elements that have a red asterisk by them
Some are mandatory in the XSDs
Some are optional in the XSDs
There are elements that have red boxes
Can someone please tell me from whence those are controlled
In version 2.X documentation there is a discussion about "Highly
Recommended" but I cannot find where these are set in V3.X
As part of a Community of Practice, we would like to highlight
elements that are of particular use
Eg mro:MD_Identification<<Abstract>>/mri:purpose
e
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
IMPORTANT - This email and any attachments have been issued by the
Australian Government Department of Agriculture and Water Resources. The
material transmitted is for the use of the intended recipient only and may
contain confidential, legally privileged, copyright or personal
information. You should not copy, use or disclose it without authorisation
from the Department. It is your responsibility to check any attachments for
viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this
email at once by return email and then delete both messages. Unintended
recipients must not copy, use, disclose, rely on or publish this email or
attachments. The Department of Agriculture and Water Resources is not
liable for any loss or damage resulting from unauthorised use or
dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no
longer want to receive a message such as this one, advise the sender by
return e-mail accordingly. This notice should not be deleted or altered
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
