[GeoNetwork-users] GN.3.2 Cannot convert ger to 2 char iso lang code
Hi.
Whenever is try to edit a metadata record i get a whole bunch of exceptions
starting with
at org.fao.geonet.util.XslUtil.twoCharLangCode(XslUtil.java:403)
The metadata in question are imports from GN-2.10.4 (via XML) and they are
in german.
<gmd:language><gmd:LanguageCode
codeList="http://www.loc.gov/standards/iso639-2/&quot; codeListValue="ger"/>
Geonetwork itself is called in German
http://cnvbrwgdit2.net.vlr.gv.at:8900/geonetwork/srv/ger/catalog.edit#/board
Are there some special configuration steps necessary in order to support
german metadata documents?
Thanks
Andy
View this message in context: http://osgeo-org.1560.x6.nabble.com/GN-3-2-Cannot-convert-ger-to-2-char-iso-lang-code-tp5289622.html
I can't help with a solution, but I see the same error in my log files for
English-language Geonetwork 3.2.x even when I'm not uploading metadata:
2016-10-06 15:07:51,699 ERROR [geonetwork] - Cannot convert English to 2
char iso lang code
java.lang.Error
at org.fao.geonet.util.XslUtil.twoCharLangCode(XslUtil.java:364)
at sun.reflect.GeneratedMethodAccessor480.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at
net.sf.saxon.functions.ExtensionFunctionCall.invokeMethod(ExtensionFunctionCall.java:690)
at
net.sf.saxon.functions.ExtensionFunctionCall.call(ExtensionFunctionCall.java:343)
at
net.sf.saxon.functions.ExtensionFunctionCall.iterate(ExtensionFunctionCall.java:224)
at net.sf.saxon.expr.Expression.evaluateItem(Expression.java:352)
at net.sf.saxon.functions.ForceCase.evaluateItem(ForceCase.java:23)
at net.sf.saxon.functions.Concat.evaluateItem(Concat.java:38)
at net.sf.saxon.expr.ExpressionTool.evaluate(ExpressionTool.java:296)
at net.sf.saxon.expr.LetExpression.eval(LetExpression.java:339)
at
net.sf.saxon.expr.LetExpression.processLeavingTail(LetExpression.java:548)
at net.sf.saxon.instruct.Block.processLeavingTail(Block.java:556)
at net.sf.saxon.instruct.Template.expand(Template.java:220)
at net.sf.saxon.instruct.CallTemplate.process(CallTemplate.java:257)
at net.sf.saxon.instruct.DocumentInstr.evaluateItem(DocumentInstr.java:278)
at
at net.sf.saxon.instruct.Instruction.process(Instruction.java:93)
at
net.sf.saxon.instruct.ElementCreator.processLeavingTail(ElementCreator.java:296)
at net.sf.saxon.instruct.Template.applyLeavingTail(Template.java:203)
at
net.sf.saxon.instruct.ApplyTemplates.applyTemplates(ApplyTemplates.java:345)
at net.sf.saxon.Controller.transformDocument(Controller.java:1807)
at net.sf.saxon.Controller.transform(Controller.java:1621)
at org.fao.geonet.utils.Xml.transform(Xml.java:486)
at org.fao.geonet.utils.Xml.transform(Xml.java:375)
at
org.fao.geonet.kernel.search.SearchManager.getIndexFields(SearchManager.java:1082)
at
org.fao.geonet.kernel.search.SearchManager.buildIndexDocument(SearchManager.java:751)
at org.fao.geonet.kernel.search.SearchManager.index(SearchManager.java:693)
at org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:765)
at org.fao.geonet.kernel.IndexMetadataTask.run(IndexMetadataTask.java:114)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
So I don't think it's specific to German or to uploading metadata...
Jo
On Thu, Oct 6, 2016 at 2:02 PM, sulu <andreas.siegel@anonymised.com> wrote:
Hi.
starting with
in german.
catalog.edit#/board
Thanks
Andy
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Jo Cook*
t:+44 7930 524 155/twitter:@archaeogeek
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18
7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
<https://twitter.com/astuntech&gt;
iShare - enterprise geographic intelligence platform
<https://astuntechnology.com/ishare/&gt;
GeoServer, PostGIS and QGIS training
<https://astuntechnology.com/services/#training&gt;
Helpdesk and customer portal
<http://support.astuntechnology.com/support/login&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Hi
Can you check what contains the element /gmd:MD_Metadata/gmd:language
element? I could reproduce the issue with a value that contains locale
information, not only the language:
  <gmd:language>
    <gco:CharacterString>eng; CAN</gco:CharacterString>
  </gmd:language>
If I change to this, works for me:
  <gmd:language>
    <gco:CharacterString>eng</gco:CharacterString>
  </gmd:language>
Jose García
On Thu, Oct 6, 2016 at 5:11 PM, Jo Cook <jocook@anonymised.com> wrote:
char iso lang code
java.lang.Error
at
at
at
at
at
at
at
at
at
at
at
at
Jo
> Hi.
exceptions
> starting with
are
> in german.
> catalog.edit#/board
> Thanks
> Andy
> projects/geonetwork
*Jo Cook*
7RL, UK
864201149.
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
2016-10-06 17:29 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
  <gmd:language>
  </gmd:language>
  <gmd:language>
  </gmd:language>
Not sure if related, but it is better to encode language using the
following (see templates provided by default):
<language>
  <LanguageCode codeList="" codeListValue="eng"/>
</language>
This is required for INSPIRE at least, and even if GeoNetwork should
support both forms, the codeList mode is safer I think.
Francois
Jose García
wrote:
> Hi,
for
> char iso lang code
> java.lang.Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Jo
wrote:
> > Hi.
> exceptions
> > starting with
> are
> > in german.
> > catalog.edit#/board
support
> > Thanks
> > Andy
> > _______________________________________________
> > projects/geonetwork
> *Jo Cook*
KT18
> 7RL, UK
> 864201149.
> projects/geonetwork
projects/geonetwork
