[GeoNetwork-users] GN 3 - MAP - MapQuest
<http://osgeo-org.1560.x6.nabble.com/file/n5288495/geonetwork_map.png&gt;
Hi
When I take a look at the map now can I see there is no longer base map! In
stead is the message from "MapQuest"
How can I fix that? Any Ideas?
B.t.w. I would like to use my own map from my geoserver instead. Using
North Pole view. (North Pole above)
View this message in context: http://osgeo-org.1560.x6.nabble.com/GN-3-MAP-MapQuest-tp5288495.html
MapQuest is no longer free for use, so you can't use it anymore. It is better
to delete it from config-viewer.xml
View this message in context: http://osgeo-org.1560.x6.nabble.com/GN-3-MAP-MapQuest-tp5288495p5288727.html
Hi Hoddi,
As explained on this issue
<https://github.com/geonetwork/core-geonetwork/issues/1697&gt;, direct access
to tiles in MapQuest has been discontinued. In my opinion the support to
MapQuest background maps should be removed from GN.
Please use any of the other providers (OSM, VirtualEarth and Stamen).
                              Best Wishes,
                                      Joana
Hi
In
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
Vriendelijke groeten / Kind regards,
*Joana Simoes <http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe
NetherlandsT: +31 (0)318 416664 <+31318416664>GeoCat bvhttp://geocat.net
<http://geocat.net>*
Thanks for quick response.
On Mon, Oct 3, 2016 at 8:19 AM, Joana Simoes <joana.simoes@anonymised.com>
wrote:
Hi Hoddi,
access to tiles in MapQuest has been discontinued. In my opinion the
support to MapQuest background maps should be removed from GN.
                              Best Wishes,
                                      Joana
Hi
In
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
Hólmgrímur Helgason (Hóddi)
CAFF - Data Manager
+354 462 3357
I've created a pull request to remove the mapquest support, here:
https://github.com/geonetwork/core-geonetwork/pull/1704
On Mon, Oct 3, 2016 at 11:58 AM, Hólmgrímur Helgason <hoddi@anonymised.com34...> wrote:
wrote:
Hi Hoddi,
                              Best Wishes,
                                      Joana
Hi
map! In
s/geonetwork
CAFF - Data Manager
+354 462 3357
